Placebo effect or actual effect...either way its producing results, right?
disclaimer---i've never used this seafoam stuff...just stirring the pot
__________________
call me by my name..Ara 2005 Mercury Metallic (NEVER shows dirt) LS430
w/black leather
w/Modern Lux
w/sport package
w/LOUSY AM RECEPTION! HEY TOYOTA! my OTHER car was a loaded 2002 Acura 3.5RLw/NAV that's usable IN MOTION!
Hey guys if you want to SeaFoam and you feel it works great, go right ahead. I have no problem with that at all. I was just pointing out that you can mix up your own can size "Seafoam" home brew treatment in about 5 minutes with approx 50 cents worth of the absolutely identical materials (readily available from Home Depot). The actual formula is by weight but this would easily be close enough - mix approximately 5 oz Mineral oil, 3.5 oz Naptha, and 1.5 oz rubbing alcohol - presto... a 10 oz 50 cent Seafoam treatment.
btw - The 128 oz size Seafoam lists for $69. That's a pretty cool markup they got going.
__________________
2006 LS 430 Black Cherry w/ cashmere interior
Factory Stock except replacement kit for console ashtray. Premium option package.
that's like saying, Dr Pepper is just carbonated water, high frutcose corn syrup, some coloring, phosphoric acid and a few other things, only 12 cents worth of ingredients. why not make your own?
after all, a can of seafoam is only about $5 (give or take a few bucks). not exactly draining my 401k (if I had one).
I understand where you are going with the Dr Pepper comparison and it is a good point. There is a convenience factor involved. Dr Pepper may not be the best example because I don't have high fructose corn syrup, coloring, and phosphoric acid, or "a few other things" sitting around my house. And more importantly I do not have access to he formula for mixing of Dr Pepper. The ingredients formula for the Seafoam product is available. And I do have rubbing alcohol, mineral oil (we use it for treating wooden surfaces) and Naptha - (aka lighter fluid) sitting around my house. Seafoam sells for about $6.50 for 16 oz but again , good point for $6.50 a can there is time saving and convienience in just buying it ready made. I just wanted folks to realize what was in it - there are no "special secret ingredients or some space age complex formula".
__________________
Dr. Pepper and all other Cola's get their flavor (aside from sweet) from a very specific mix of essential oils that you can't just get and mix properly without lab equipment. That is a red-herring.
What I use instead of SeaFoam is intake cleaner. Some state they are catalytic converter safe if you are worried. I spray about a third of the can on the throttle-body and use a toothbrush to remove the buildup around the edge of the butterfly valve if it doesn't come off with just spraying. I start the car and it cranks for a while before it will run without throttle added. Then I have a helper run the motor under 3k rpm while I spray the rest of the can directly into the throttle body. White smoke etc is involved, as is improved off-idle performance. This has made a significant difference each time I have done it (60k + miles on each vehicle).
I don't add things to my motor-oil but I do use MoPar Fuel-injector cleaner or Techron fuel additives. A friend was told in his ASE classes those are the only fuel additives that work well. I have had improved mileage and performance improvements as well.
__________________
05 LS430 Sandstone 46k mi
04 STi Blue 82k mi
98 Triumph Daytona Red 7.2k mi
94 Integra GS-R Green KIA
99 Camry Gold, Sold
90 Accord Gold KIA
73 Beetle Yellow Sold
I have changed the oil several times since Ive had it and the usual 3000 - 3500 miles had the dark brown used oil look to it. This time however the oil was black, I mean BLACK. As far as the temp gauge not a drop that would cause an eyepop but a general "running a tad bit cooler" of the engine in general. Im not trying to start a heated debate but I havent torn up my ride, (LOLOL) and I got a little better performance. call me crazy, lol.
