Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS430
Sign in using an external account
Register Forgot Password?
LS430 Brake Pad Replacement w/ Photos
Thread Tools Search this Thread Display Modes
Old 05-11-09, 06:44 PM   #31
AlexusAnja
Trader Score: (0)
AlexusAnja's Avatar
Default Repair or replace
Quote:
Originally Posted by danxp View Post
i'm about to tackle a brake pad change myself and had a few questions...
- if the brake wear sign comes on, does that mean the sensor is now "broken" and it has to be replaced?
- can i get away with just replacing the front pads only? i was told that the fronts wear out twice as fast as the rears... is this true?
- where's the best place to get oem pads? and for how much?
thanks for the great writeup, turbotodd! (and moogy who originally inspired turbotodd)
1. easiest is to replace the sensor so you have a sensor again, but you can "trick the system" by soldering or tieing the contacts together and then just not install the sensor back. Hang it (twist tied) to a none moving piece on the back.
2. most cars the fronts do wear out faster than the rears, so you could be able to replace just the fronts. You have to check the wear.
3. I've found Irontoad.com to always be competitive and most times better than others.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
'10 MDX blk/blk
'04 LS430 CL blk/blk (I'm on cloud 9)
'99 RX green/beige - (still smashing, but it's the beater)
N:Quebec E:Boston W:Chicago S: Orlando
AlexusAnja is offline   Reply With Quote
Old 05-12-09, 05:53 AM   #32
danxp
Trader Score: (0)
yes, i just ordered from them... both fronts and rears for $103 shipped... will be attempting the brakes this weekend...
danxp is offline   Reply With Quote
Old 05-19-09, 07:31 AM   #33
danxp
Trader Score: (0)
with the exception of a lost cotter pin (replaced with a paper clip), the brake pad replacement was a success this weekend... i inspected the rears and they seemed like they still had some good life to them so i left them there after inspection... thanks again to turbotodd and moogy for their writeups...
a couple of notes i might add...
- when replacing the fronts, turn the wheel to the direction you want to work in... the fronts were much easier to get to than the rears because of this...
- when pulling out the rod, with your other hand, firmly push in the support bracket (or whatever that's called) so that all you need do is pull out the rod...
- when pushing in the pistons with the old brake pads, use a better c-clamp than i did... it was a little too big to really gain enough leverage to push in the piston(s) enough, so i just used my pliers and pushed it in while using leverage against the rotor...
question...
when i pulled out the old brake pads, the rotor was free to wiggle about unsecured... seemed like the rotor should have been secured to something, no? is this normal? i mean, everything was tightened all up when i put everything back together, but seemed kinda strange...
a fun project, that took me 3 hours cause i didn't know what i was doing and i was using my car's scissor jack and didn't have the right tools... could probably do it now in under an hour if i had the proper equipment...
Old 05-19-09, 07:07 PM   #34
AlexusAnja
Trader Score: (0)
AlexusAnja's Avatar
Default Paper clips?
question...
Paper clip? Heavy duty, or regular duty? I have not done the brakes yet, so not sure how much force or sheering the clip will be subject to, but I would not use a clip that could rust and possibly break off at some point. Does your significant other have hair pins? That might work better.
As for the rotor being loose, again, I have not changed it yet, but typically a rotor is held onto the backing by two screws. I have worked on some cars where the rotor does sit loose and the tires being mounted will keep the rotor in place. I would have thought the LS would not be a free floating type.
For timing, a full four wheel job takes me about an hour, and all I have of anything special is a 4-ton floor jack. Everything else is manual labor. You'll get better as you get better tools.
__________________
'10 MDX blk/blk
Old 05-20-09, 05:43 AM   #35
xschop
Trader Score: (0)
Default LS430 Brakes
VERY good write up. I just did a Big Brake Conversion using these LS430 calipers on a Porsche 944. I do have a question. If you know what the piston diameters are on the 2-pot rears? I just may swap them out also....Thanks again for the work on the pictorial....
xschop is offline   Reply With Quote
Old 05-20-09, 05:45 PM   #36
bad newz
Trader Score: (0)
that wuz a great help me how much is it 2 change sensor
bad newz is offline   Reply With Quote
Old 05-20-09, 06:21 PM   #37
AlexusAnja
Trader Score: (0)
AlexusAnja's Avatar
Default Change yourself?
Quote:
To do it yourself, or by Lexus. If you buy the part, it's under $50 (aftermarket, not Lexus) up to $80 for Lexus. Then of course there is labor. I'm sure for two sensors it will run you over $200 installed.
Hope someone can chime in with better news.
__________________
'10 MDX blk/blk
Old 11-07-09, 04:41 PM   #38
StanVanDam
Trader Score: (0)
Excellent write-up and pics. Your LS430 went at least 75000 miles before changing the pads? Is this typical? How long do the LS430 pads usually last?
__________________
2002 LS430 UL / 130k kms / Blue Onyx Pearl / Ecru Bird's-Eye Maple / Ecru Premium Leather
VAISTech SL2Vi / iPod Touch 3G / Toyota Lexus Navigation DVD Gen 2-3 v10.1 86271-33049
90915-20004 oil filters / FIGS Engineering trunk struts / Interstate MTP-24F battery
225/55/17 Michelin X-Ice Xi2 + Macpek AZZ755CG rims
225/55/17 Michelin Primacy MXV4 + OEM chrome rims
FormulaOne Pinnacle 15 tint
Zaino Car Care Products
StanVanDam is offline   Reply With Quote
Old 11-09-09, 05:41 AM   #39
toantran99
Trader Score: (0)
Nice write up.
toantran99 is offline   Reply With Quote
Old 11-09-09, 06:52 AM   #40
stvincent
Trader Score: (4)
stvincent's Avatar
great write up and detailed pics.. thx.
__________________
2008 IS-F Starfire Pearl/ Black
2005 LS430CL Black Onyx/ Black
2008 GS350 AWD Starfire Pearl/ Black
2003 ES300 Black Garnet/ Black
stvincent is offline   Reply With Quote
Old 11-09-09, 04:51 PM   #41
Geminiking
Trader Score: (0)
wow...changing brakes on a LS430 is piece of cake. Ive changed brakes several times on my hondas which i consider easy but this is just ridiculously easy compare to them. Its a same how I read on another lexus forum that a dealership wants to charge $800 to do front and rare brakes including resurfacing the rotors.
Geminiking is offline   Reply With Quote
Old 11-09-09, 06:34 PM   #42
LS430inDE.
Trader Score: (0)
LS430inDE.'s Avatar
Send a message via AIM to LS430inDE.
Talking think pink!
Quote:
Maybe it was one of those cute, pink plastic coated paperclips? LOL!
Excellent writeup btw!!!
__________________
call me by my name..Ara
2005 Mercury Metallic (NEVER shows dirt) LS430
w/black leather
w/Modern Lux
w/sport package
w/LOUSY AM RECEPTION!
HEY TOYOTA! my OTHER car was a loaded 2002 Acura 3.5RL with NAV that's usable IN MOTION!
LS430inDE. is offline   Reply With Quote
Old 11-10-09, 12:07 PM   #43
toantran99
Trader Score: (0)
Thank goodness you changed your pads, there were really worn out.
Old 01-01-10, 06:30 AM   #44
roumieh200
Trader Score: (0)
Curious to change to the sensors, what is the price of fronts and rears ?
By the way they are located on one side in front and back side (right side).
FOUND THEM HERE:
http://www.clublexus.com/forums/ls43...termarket.html
roumieh200 is offline   Reply With Quote
Old 02-24-10, 11:46 AM   #45
StanVanDam
Trader Score: (0)
OP: I noticed that you used Disc Brake Quiet and then used the synthetic grease on top. I found the following tidbit of info saying to not to use disc brake quiet for shimmed pads (which all LS models have):
"Thank you for you interest in CRC’s products. You had inquired whether it was better to use Disc Brake Quiet over Synthetic Brake Caliper Grease for quieting brake noise on your shimmed brake pad. We would recommend using Synthetic Brake Caliper Grease for your shimmed brake pads. Disc Brake Quiet is meant for usage on non-shimmed brake pads. The Disc Brake Quiet’s tackiness will cause the shimmed pad not to work properly. Additionally, the Synthetic Brake Caliper Grease will cut down on the corrosion on the brakes. Please let us know if you have any additional questions."
"CRC's engineers state that brake pads with a slice of metal built right onto the backing plate (they call this a metal gage riveted to the backing plate) is NOT a shimmed brake pad. The only pad design they consider to be "shimmed" are pads with actual, separate shims like those that are featured in the OEM pads. Shims that are detachable and must be user-installed. Any pads with riveted, pre-installed metal pieces that are not user removable are not considered shimmed pads."
Source: http://tl.acurazine.com/forums/showthread.php?t=617779
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Changing Valve Cover Gasket & removing Air intake Box DIY TriniLex SC 430 5 12-13-12 08:30 PM
Is300 w/ LS430 projectors & DDE (56k not okay) lilboi Lighting 35 01-30-12 11:31 PM
Factory OEM Chrome Rims - looking to trade for 5 spoke OEM wheels skassamali LS430 11 09-22-11 09:10 PM
Well guys i totaled my car, goodbye GS hello LS sakataj GS - Second Generation 47 04-04-11 10:41 AM
Complete built cylinder heads for the GS400/430 and SC430, Only at MVP!! Chops@MVP Club Lexus Vendor Marketplace 3 09-10-08 06:52 AM
Tags
2003, 2005, brake, change, club, forums, lexus, ls, ls430, pad, pads, pics, rear, replace, sensor
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
