UL stock air suspension to steel springs conversion infos
Old 06-26-14, 10:37 AM
  #151
choi0706
choi0706's Avatar
is there a difference between left and right? on the websites they have left and right, and also what about springs? there appears to be 3 different sets of springs.. rough road/normal/sport
Old 06-26-14, 12:49 PM
  #152
BNR34
BNR34's Avatar
Yes
3 different spring rates for you to choose.
Old 06-28-14, 08:34 PM
  #153
choi0706
choi0706's Avatar
does anyone have a list of parts if not buying from dealer? it appears some parts are not offered through rock auto but it it may come with the strut mounts?
Old 07-03-14, 12:21 PM
  #154
alanchad
alanchad's Avatar
Default A few questions on air suspension conversion please
The driver side front air cylinder(shock) collapsed on my 2001 ls430ul,
so I purchased new shocks and springs from Sewell to convert.
My questions are:
1. at what point in the conversion process do you pull the compressor fuse?
2. are the suspension control actuators on top of the shock removed and discarded or what?
3. can the air lines be removed from the shock without the special tool? If so, how?
4. according to Sewell, the left and right side front replacement parts are the same,
and the left and right side rear replacement parts are the same. I understood them to be
different.
Thanks in advance from an old Vietnam vet.
Alan
Old 07-03-14, 03:04 PM
  #155
Lavrishevo
Lavrishevo's Avatar
Hi Alan,
Read through this thread carefully. It has all the info you need. Don't remove any of the air suspension sensors. Just pull the fuse to the compressor. It can be removed if you want.
https://www.clublexus.com/forums/ls4...ion-infos.html
Old 07-04-14, 06:33 PM
  #156
Bon
Bon's Avatar
1. at what point in the conversion process do you pull the compressor fuse? I pulled mine when I was done with installing the new shocks and springs.
2. are the suspension control actuators on top of the shock removed and discarded or what? Yes, they are just removed. Mine are somewhere just sitting in a box.
3. can the air lines be removed from the shock without the special tool? If so, how? I don't know how you're supposed to do it. The lines are plastic so I just cut them with wire cutters. Done.
4. according to Sewell, the left and right side front replacement parts are the same, and the left and right side rear replacement parts are the same. I understood them to be different. Yes, they are the same. Lexus assigns different numbers to the right and left so they can keep track of which side was worked on or replaced. It's just for record keeping.
Old 07-04-14, 08:10 PM
  #157
Lavrishevo
Lavrishevo's Avatar
If you remove the height sensors you will have warning lights on your dash all the time. It's up to you...
Old 07-05-14, 09:02 AM
  #158
Bon
Bon's Avatar
Lavrishevo is correct. I just left them alone as they're not bothering anything.
Old 08-21-14, 09:41 AM
  #159
guitarmike
guitarmike's Avatar
Did anyone ever figure out the flashing AFS light situation? I have a client who has this type of suspension installed and wants the warning lights off. With the 40amp AirSus fuse pulled, the instrument panel reads height hi with the red triangle. If I replace that fuse and pull the 20amp AirSus fuse from the driver side kick panel I get the flashing afs light. Any insight?
Old 08-21-14, 10:05 AM
  #160
guitarmike
guitarmike's Avatar
Is there anyway to get rid of the height hi message?
Old 08-21-14, 10:06 AM
  #161
guitarmike
guitarmike's Avatar
Anyway to get rid of the height hi message?
Old 08-21-14, 10:39 AM
  #162
Lavrishevo
Lavrishevo's Avatar
Reinstall height sensors. Otherwise, you will not be able to disable the warning. Or possible trick the height sensor connector at each wheel. Afs and the air suspension use the height sensors.
Old 08-21-14, 10:41 AM
  #163
guitarmike
guitarmike's Avatar
They are all installed and plugged in.
Old 08-21-14, 10:47 AM
  #164
Lavrishevo
Lavrishevo's Avatar
Did you try adjusting them? The computer may think their out of whack. Try to adjust each sensor so when the suspension is loaded the sensor is in the middle of its rang of adjustment.
Old 08-23-14, 06:00 PM
  #165
jmscott
jmscott's Avatar
LOL. Just a shout out to guitarmike who managed to find a solution to the height high issue in my 2004 UL. i told him that i'd give him a hug and kiss if he was able, when we spoke in the shop.
here's your virtual hug!!
Quick Reply: UL stock air suspension to steel springs conversion infos
