UL stock air suspension to steel springs conversion infos
#136
2004 LS430 UL Air to Steel conversion - Blinking AFS OFF Light on Dash
As many of you already knows, the 2 rear air struts on my UL failed, I have decided to convert my car to conventional steel springs. Many UL owners have shown interest in this conversion to avoid keep paying the very high price of the air struts, so I want to start this thread to share all the infos I found and document the whole process.
Today, I think I stumbled, solved the biggest question of the conversion, how to shut off the air suspension computer without triggering an error message from the main computer.
The main objective is to shut off the air compressor, since we don't want it to keep pumping air if the height sensors tells the computer the car is sitting too low.
I found 2 air suspension fuses and 1 air suspension relay, all I did was pulled the fuse to the air compressor. That disabled the air compressor, and to my pleasant surprise, that didn't trigger any error message or code or blinking light
How do I know I disabled the air compressor? The car doesn't go up when I press the "high" button, the "height Hi" message still came on in the cluster, but the air compressor didn't come on.
So that was it, that is all I care to disable. The air suspension computer can think whatever it want to think, I don't think that does any harm. Not that I can think of anyway, if you guys can think of anything, please let me know!
Now I am off to check out how to remove the rear power seats to get to the top struts mounting nuts.
He did mention that he had to disconnect the leveling arms due to some mechanical conflict. I'm not sure if that has anything to do with the blinking light error.
Any suggestions??
#137
I recently had my 2004 LS430 UL upgraded to the Steel Suspension - removing the Air Suspension. My mechanic followed your instructions - to remove the GREEN Fuse - but I still have a blinking AFS OFF light.
Any suggestions??
Any suggestions??
#139
YES - confirmed - he completely removed the sensors.
BUT - I'm worried. He said that there was an interference in the front that FORCED him to remove the sensor.
I also noticed that the clearance on the front wheel well is SUBSTANTIALLY less than the clearance on the front end. I think I may have received incorrect "Front Springs" (I purchased an "open box" set of Tanabe springs - where the front springs were installed / returned. I think someone did a switch-a-roo and sent the wrong ones back.)
So... looks like I'm going to order ANOTHER set of TANABE NF210 springs ... and hopefully when I replace the fronts they will look like the rears... and the SENSOR Brackets will not have interference (I hope).
#140
#141
Is been a long time, but I remember once you removed the seat bottom (just pull straight up on the front edge), you would see all the mounting bolts for the rear seat back. Just look around, is very easy to figure out where all the mounting bolts are. I did all of that without a shop manual.
I might had a diagram of how the rear seats go together at the time, go find one online or ask the dealer's part department to print you one, just pretend you want to buy something
#143
Replacing air shocks with coilovers
Hi all, hope I'm posting this in the right place, I live in Britain and have a UK spec LS430 which I believe is the equivalent of the UL spec you guys have, the isn't much information on swapping to springs this side of the pond (we only had the option of air shocks) so I was hoping somebody could provide a bit of info. From the service history the car has traveled nearly 150,000 miles on its original shocks and having read horror stories this scares me somewhat, but what scares me more is that it feels like a capsizing battleship under enthusiastic cornering.
Ideally I would like to fit a set of BC Racing adjustable BR spec coil-overs (as the cost less than a single air shock), replacing the air shocks is not an option as due to our used car market a set would cost more than the value of a LS430, and plus I would also like a firmer ride. Not bone shaking however I would prefer to have my enthusiasm for cornering limited by the sense that the back may lose traction instead of the sense that the entire vehicle may roll over.
Anyway back to the point, can I simply disconnect the air shocks and replace with coil-overs or will this throw a bunch of VSC errors? And if it does can I pull a fuse to the air compressor or something to make them go away? Also with the air shocks gone I know the height control switch will not do anything but will the sport/normal one still work? (I think I read somewhere it adjusts more than the shock dampening).
Thank you very much for any help.
#144
No VSC errors to my knowledge. Just need to pull the fuse for the compressor. The other option is to go with a Bilstien or KYB struts and Tanabe springs. I did this on my LS400 and I really liked the balance between comfort and performance.
#145
Have you inquired about these new Tanabes? Anyone know anything about them? Sure they're more expensive than BC but probably get what you pay for...
http://www.tanabe-usa.com/z40.asp?id=22
#147
美少女戦士セーラームーン
The advantage to BC's is that you can get custom spring rates and you can add Swift springs to make them ride even better.
#148
Leiptr,
Did you ever resolve this issue and how? I did the conversion on my 02 LS using the OEM sport shocks and Tanabe NF210 springs and am getting -2.2 degrees of camber. The alignment shop is worried that if they bring it within spec the tires are going to contact the fender under load.
Did anyone else run into camber issues with the swap? Any help is greatly appreciated.
Thanks, Mike
Thanks, Mike
Does anyone have a problem with the tires wearing on the inside? About six months after performing my upgrade I blew a rear tire and when I swapped it with the spare,I noticed the tire was worn all the way through on the inside. After examining the rest of the tires, I found the same issue on all of them and had to replace all four tires. After replacing the tires, I had another alignment and was told that since I lowered the car the rear tires couldn't be aligned properly and I had to get custom rear control arms (@295 each + labor). Now here is is six months later and I've already blown another rear tire and the other is goign to blow soon as well (the front tires seem to be fine though). I'm also having a problem with the left front tire (driver side) rubbing against the frame of the car. It's so bad now that the metal is cutting into my tire.
Did I miss some part of the conversion that's causing my tires to wear unevenly on the inside? At $350 a tire, this is starting to get expensive considering they only last six months. Would a camber kit like the one mentioned in the link below fix the problem with tire wear?
https://www.clublexus.com/forums/clu...-gs-ls430.html
#149
Leiptr,
Thanks, Mike
Thanks, Mike
#150
guys i have a quick question if anyone can answer.
i have stock 2002 with 17 inch rim with 123000 miles on them, has anyone noticed a difference in ride quality with just changing the oem shocks non ul with air, after 123000 a lot of dealer mechanics say the shocks are still good my car rides a little rough even with michelins, no suspension issues, i want to see if anyone has changed the kyb and had better ride quality thank you
