Bad Wheel Bearing- Cost to Fix and/or Degree of Difficulty for Replacement
Old 08-11-08, 04:16 AM
Nauticalx
Nauticalx's Avatar
Default Bad Wheel Bearing- Cost to Fix and/or Degree of Difficulty for Replacement
02 LS430 UL developed a bad wheel bearing at the driver's side front wheel at around 90k. Thumping noise and vibration at highway speeds which gets worse on turns. I looked for the parts and it seems that there is two options- 1) a bearing and 2) a hub assembly with bearing included. I was wondering which to replace because the cost of the two is like night and day.
Bearing~$50
Hub Assembly~$350 (I noticed it includes the wheel speed sensor and all as well)
Has anyone dealt with a bad bearing on the LS430? Also, I am not able to get to my repair manual CD so if anyone has one handy, would you be kind enough to post the replacement procedure? Is this a DIY or a repair shop trip in the making? TIA
Old 08-11-08, 08:03 AM
vcheng
vcheng's Avatar
I have had a bad left rear wheel bearing on one of my previous LSs but it was taken care of under warranty.
The bearing will require a hydraulic press so it is a job for a workshop unless you have the proper tools.
However, I would suggest contacting Lexus Corporate for goodwill help with this. They just might agree to the labour if you pay for the parts, and the whole thing if you are lucky.
Old 08-19-08, 07:39 AM
Nauticalx
Nauticalx's Avatar
OK, so I'm looking at my repair manual and it indicates in the suspension section that the bearing should be replaced however only the removal of the hub and then the speed sensor from the hub is detailed. No information is given on how to remove the bearing from the hub.
Does Lexus recommend the entire hub be replaced? If so, why does the manual say to replace the "bearing?" I know that the bearings are sold so do any of you know where in the manual I can find instructions to remove the bearing from the hub? TIA
Old 03-05-11, 11:50 PM
TubbyGs430
TubbyGs430's Avatar
the bearings cant be pressed out you have to buy a new wheel hub bc its one unit and the bearing are sealed
Old 03-06-11, 07:07 PM
rferris
rferris's Avatar
Default front wheel bearing replacement LS430 2002
I replaced both bearings on my 02 remove wheel, tie up caliper remove 4 bolts for hub assembly. hardest problem is removal of hub because of corrosion of alumium and steel after much hamering it finally came off ,clean up the hub mount ,replace with new hub tighten hub bolts, I replaced the bolts and caliper bolts also, cost of $250 each for hubs This was over a year ago.
Old 03-07-11, 03:02 AM
JamesHuang
JamesHuang's Avatar
How common is this problem? Anyone else with high mileage LS430's like myself currently going through this repair?
Bearing~$50
Old 03-07-11, 11:49 AM
toantran99
toantran99's Avatar
Lexus charged my $500 to replaced the wheel hub bearing. The bearing is bad but they said they need to replaced the whole thing.
I had it replaced since I destroyed my front left suspension when hitting the curb.
Old 03-07-11, 04:33 PM
yangins
yangins's Avatar
If you are paying some to do the repair might be cheaper to replace the hub.
Old 09-28-11, 06:37 PM
Oldguys
Oldguys's Avatar
Default Rear Hubs
Drivers side rear hub went bad at 132K on 2006 LS430. Passenger side rear hub went shortly thereafter. Probably best to do both at same time. Roughly $500 each. Not a DIY job. Huge pain in the butt. Front hubs are plausible for DIY, not the rears.
Old 09-29-11, 02:11 PM
Jsteezy87
Jsteezy87's Avatar
i had my right front bearing go bad at 1758xx miles. was covered underdealer warranty where i got the car, however they did have to send it out to be pressed out/in. i do know from work ive done on 4wd rearends that if bearings have to be pressed in then have it done. pita if you try yourself.
Old 09-30-11, 06:33 AM
groomerz
groomerz's Avatar
I did my front passenger side. Replaced hub assembly got from rock auto timken brand, like others have said expect the hub to be pressed out. Really wasn't difficult , I unbolted caliper , removed rotor, unbolted upper ,, used the 2 hammer method to pop upper ball joint from steering knuckle ( take 2 hammers and strike the sides around the joint at the smae time and it pops apart). remove the 2 bolts t bottom of steering knuckle, I tried for over an hour to get bearing out of knuckle no luck, I then took the steering knuckle and the new bearing to a local repair shop that had a press. the popped old one out and new one in for 35.00. reassembled .
Old 09-30-11, 06:52 AM
Boomer01
Boomer01's Avatar
I took mine to a Toyota dealer and it was around $600 to replace my right front.
carferna
GX - 2nd Gen (2010-2023)
19
03-30-20 06:55 PM
Bocatrip
06-25-18 11:01 PM
Engel
03-20-18 11:29 PM
Gil Smash
04-19-13 05:23 PM
Sup2jzgte
Suspension and Brakes
04-23-10 10:42 PM
Quick Reply: Bad Wheel Bearing- Cost to Fix and/or Degree of Difficulty for Replacement
