Side Mirrors LED Light Install w/ Pix
Old 04-24-10, 10:18 PM
  #91
airtime
airtime's Avatar
Wow, a blast from the past All bulbs still working nearly 2 years now.
Old 06-06-10, 07:08 AM
  #92
stropp
stropp's Avatar
Default Anyone replace the DRL's with LED's?
Old 06-06-10, 02:48 PM
  #93
RA40
Super Moderator
RA40's Avatar
Thanks for the write-up! Helpful for even us older gen LS owners.
Old 06-06-10, 05:32 PM
  #94
TJW98LS
TJW98LS's Avatar
You should make puddle lights for you LS400
To this day I still like your White one. Do you still have the L-sportline wheels?
Old 06-06-10, 09:43 PM
  #95
RA40
Super Moderator
RA40's Avatar
I've thought about adding them to the mirrors, that's why I liked this thread.
Same config as the pic, lots of wheels I like but none I'm willing to drop coin on. Don't see the L Sportlines often, they are pretty ancient though. I've been getting UCF3X urges so I'm taking in the discussions.
Old 06-07-10, 01:24 AM
  #96
TJW98LS
TJW98LS's Avatar
YOU CAN DOOOO ITTT!!! Well, the mirrors that is.
I've had all the LS430 wheels on my old LS400 (17's and 18's) + those ancient L-sportline chromies, and I will tell you... with some spacers for the rear, those 18" LS430 5-spokes looked the best on it... as you can see, I've not changed my signature.
Old 06-12-10, 08:25 PM
  #97
froboy272
froboy272's Avatar
Originally Posted by Tee
FYI:
The 194 bulbs (wedge) will also work in all the doors, and the lights above the daytime running lights.
Just curious when these little bulbs above the drl's are actually on. i never even noticed they were there until i read this post and iv never noticed them at all.
Old 06-12-10, 08:43 PM
  #98
Tee
Tee's Avatar
Yep the bulbs can be seen if you turn the park lights on when the car is off, and engage the parking brake, then crank the up you will see them. When the parking brake is engaged the DRL's won't turn on until you release the parking brake, however if the car is running and you engage the parking brake the DRL's will remain on. I changed mine out to amber LED's, here is how you do it...
Frist remove these covers (plastic clips pop right out)
Once you remove them you will see the bulb socket
Twist to unlock the bulb socket to remove
And viola!
Old 09-18-12, 03:04 PM
  #99
GaborL
GaborL's Avatar
Sry, this might be a noob question.
Is there any way to change/replace this light bulb without having to disassemble the whole mirror?
Meaning, Can't I just pry the clear plastic cover from the bottom gently, and reach in for the bulb?
Any help is appreciated.
Old 09-19-12, 09:27 AM
  #100
LsBanGer43
LsBanGer43's Avatar
Check page 3-4 u can use a credit card or a flat head screwdriver, a lot of info you should read through the pages.
Old 08-25-13, 02:52 AM
  #101
HRDBDY808
HRDBDY808's Avatar
I prayed out the plastic cover out however its was a pita to put it back also . That being said once it was all done I did a final test to check if lights operate and it didn't . So I had to go to back n opened it up and now it' doesn't work, the LEDs I got from ddm, so I found the wires were strip from putting it in . I redid them and its funny that if I press unlock its shuts off and lock it turns on , if I put the stock back it wouldn't work , what could be the issue here , I might have to just pull the whole assembly out I believe . Lmk any ideas what could be happening tnx
WIL44
07-06-21 03:00 PM
talwang
RX - 3rd Gen (2010-2015)
33
03-24-14 04:52 AM
Ziggy716
02-05-14 09:30 PM
rz1004
08-04-11 06:02 PM
Weapon F
04-25-11 08:00 PM
Quick Reply: Side Mirrors LED Light Install w/ Pix
