19x10 +35 with 245 40 19 tires
Old 03-12-08, 09:34 AM
mikemareen
mikemareen's Avatar
Default 19x10 +35 with 245 40 19 tires
keep in mind I said 40 series, not 35 series.
rub or no rub ?
Old 03-12-08, 10:27 AM
racinstyle
racinstyle's Avatar
depends on what brand of tires, but I would say its going to rub
Old 03-17-08, 08:10 AM
motohide
motohide's Avatar
The Rear tire will clear with tons of space left... Probabaly good 16mm from fender inner edge and no issues...
The front tire will rub slightly if the car is low and steering turns and strokes at the same time. (Like when turning into steep driveways) but for the most part, should be OK if the drop is mild.
Old 03-17-08, 10:22 AM
masboy
masboy's Avatar
mikemareen, i have 19x9 +38 w/ 255 40 19 tires and it's not rubbing at all before I drop the car. You should be fine......
AZGHOST
10-31-13 11:09 PM
pinoiryder
09-09-13 10:15 AM
jbone29
08-11-12 02:30 PM
100degrees
Wheels, Tires & Brakes Forum
06-13-12 04:29 AM
Quick Reply: 19x10 +35 with 245 40 19 tires
