Oil "overfill" seems to be common ..
Old 10-19-08, 07:02 PM
AlexusAnja
AlexusAnja's Avatar
Default Dip that stick....
Originally Posted by campisi
MTA: If you are filling your engine till it reads at the high mark then you are on the verge of overfilling. In between the two marks is correct.
I agree, between the two marks is usually one quart. So, anything between the two marks is "golden" and you're safe. I'm just saying that 5.5 qts. brings you to the top mark (full), so measure that last .5 qts. real good.
And yes... we know it's quarts. We're going by whatever qts. on the Mobil 1 bottle says. in my case, it's a 5 quart jug, so I just poured it all in. We're living in AMERICA ! We don't use that metric stuff. The only time we use liter is for 2 liter soda bottles... and we sure won't be using any "imperical" measurements either.
As reference, on my '95 Civic and '92 Integra, I've always followed the owners manual units and it's always brought it very close to the top mark, and the Civic is running 260K right now somewhere in South Africa, while my Integra is still going strong at 225K, so that top hash is okay too.
Old 03-26-15, 05:34 AM
Blueheart5
Blueheart5's Avatar
Default Please read these specifications I found
All dimensions are in inches unless otherwise noted.
Exterior Dimensions (in.)
2002 Lexus LS 430
Wheelbase
115.2
Overall Length
196.7
Overall Width
72.0
Overall Height (Unloaded)
58.7
Air suspension
57.9
Tread Width
Front/Rear
61.8/61.8
Air suspension
62.0/62.0
Ground Clearance
5.7
Air suspension
5.9
Coefficient of Drag (Cd.)
0.26
Cd. with Air suspension
0.25
Interior Dimensions (in.)
Seating Capacity
Headroom
Front
w/moonroof
39.6
38.1
Rear
w/moonroof
38.0
37.9
Legroom
Front
44.0
Rear
37.6
Shoulder Room
Front
58.3
Rear
58.2
Hip Room
Front
56.7
Rear
57.3
EPA Passenger Volume (cu. ft.)
107.2
EPA Trunk/Cargo Index (cu. ft.)
20.2
with rear air conditioner
17.5
Engine
Designation
3UZ-FE
Type
Four Cam, 32 valve V8 with VVT-i
Displacement
4.3 liters 4,293 cc (261.9 cu. in.)
Bore x Stroke (mm / in.)
91 x 82.5 / 3.6 x 3.3
Compression Ratio
10.5:1
Horsepower (SAE)
290 hp @ 5,600 rpm
Torque (SAE)
320 lb.-ft. @ 3,400 rpm
Oil Capacity (liters / qts., without oil filter)
6.0 L / 6.3 qts.
Oil Type
SH 5W-30
Cooling System Capacity, (liters / qts.)
11.0 L / 11.6 qt.
Fuel System
EPA Ratings (mpg - City / Highway)
18 / 25
Fuel Requirement (min.)
91 Octane (R+M)/2, Premium Unleaded
Tank Capacity (liters / gal.)
84.0 L / 22.2 gal.
Electrical
Alternator (ampere)
100
Battery (voltage/amp. hour)
12/55
Starter (kW)
Drivetrain
Layout
Front engine, rear wheel drive (FR)
Transmission
5-speed automatic electronically controlled transmission with intelligence (ECT-i)
Type
A650E
Gear Ratios:
1st
3.357
2nd
2.180
3rd
1.424
4th
1.000
5th
0.753
Reverse
3.431
Final Drive
3.266
Steering
Type
Vehicle-speed sensing progressive power rack and pinion
Overall Steering Ratio
15.7:1
Turning Circle (ft.)
37.4
Turning, Lock to Lock
3.52
Vehicle Weight
Curb Weight (lbs.)
3,955
GVWR (lbs.)
5,140
Weight Distribution, F/R (%)
53/47
Suspension
Curb Weight (lbs.)
Four wheel independent double wishbone suspension
Front
Coil springs, gas-filled shock absorbers and rebound springs, anti-lift and anti-squat geometry, high-mount upper arm and low compliance steer characteristics
Rear
Coil springs, gas-filled shock absorbers, anti-lift and anti-squat geometry, reverse angle upper arm and eccentric cams for re-alignment
Brakes
Type
Four wheel ventilated, power assisted disc brakes with Anti-lock Braking System (ABS) and Brake Assist (BA)
Front disc diameter (in.)
12.4
Rear disc diameter (in.)
12.2
4 channel, 4 sensor (integrated with VSC)
Parking Brake
Drum
Wheels & Tires
2002 Lexus LS 430
Wheel Size (in.)
16x7 JJ
Type
Aluminum alloy
Optional Wheel Type 16"
Chrome
Tire Size
225/60 R16 H-rated
Summer Tire
Goodyear Eagle GA or Bridgestone Turanza ER 33
Optional All Season Tire
225/60 R16 H-rated Goodyear Invicta GAL or Dunlop SP Sport 4000
Optional Wheel Size (in.)
17x7 ¸ JJ
Optional Wheel Type 17"
Aluminum alloy or Chrome
Optional Tire Size
225/55 R17 H-rated or W-rated
Spare Tire/Wheel
Alloy with full-size tire
Performance
0-60 mph acceleration, seconds
6.3 - TMC figure
mile acceleration, seconds
14.7 - TMC figure
Top track speed, mph
131 (electronically limited)
Redline/maximum rpm
6,350
Old 03-26-15, 05:39 AM
Blueheart5
Blueheart5's Avatar
Default Go to for specifications
Go to www.new-cars.com
And look up specifications of a 2002 LS-430
It clearly states 6.3qts without oil filter the same for all 3UZ-FE engines on the Lexus LS-430
Old 03-26-15, 07:23 AM
LiCelsior
Retired
LiCelsior's Avatar
my OEM lexus owner's manual says otherwise, I rather follow that spec then a .com site.
Rising2010
03-18-21 06:32 AM
dysLEXic
Maintenance
03-03-08 04:05 PM
silver250
05-08-06 12:56 PM
ferix
07-23-05 07:00 AM
Wald GS
Maintenance
18
04-16-03 10:49 AM
Quick Reply: Oil "overfill" seems to be common ..
