LS430 navigation bypass/unlock?
Old 07-10-10, 03:25 PM
  #31
Oldguys
Oldguys's Avatar
Is there a way to bypass the Nav agreement screen without installing a switch on the 2006 model?
Old 09-28-10, 09:48 AM
  #32
sadwafair3
sadwafair3's Avatar
does this work on an 98 ls 400 with touch screen nav
Old 10-04-10, 08:18 AM
  #33
94LSon20
94LSon20's Avatar
y is the a/c on 65 when its 63 out!? haha
Old 10-05-10, 01:44 PM
  #34
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Sadly, it does not.
To dehumidify the air most likely.
Old 02-24-14, 02:42 AM
  #35
KING
KING's Avatar
Sorry, to bump this very old thread. But I am looking for a way to access override on my NAV, without buying a lock pick, because simply they are so damn expensive.
My car is a 2006, I'm not sure what GEN my nav is though. I think it's the newest update.
Old 02-24-14, 08:11 AM
  #36
Gene01
Gene01's Avatar
The 2006 LS430 uses the Gen4 disks.
There is no known way to bypass the "I agree" screen on version 5.1 and later.
I should have made it more clear - No way without adding some hardware.
Old 02-24-14, 10:57 AM
  #37
Tom57
Tom57's Avatar
If you add the VaisTech MML audio interface adapter, after a few seconds after start-up, the "I Agree" screen automatically switches to the map without having to touch "I Agree". This is a nice feature, and it is exactly how later generations (Gen 5) Toyota operate.
Old 02-24-14, 11:19 AM
  #38
BeatSonic
Sponsor
BeatSonic's Avatar
We at Beat-Sonic also have a solution to override the NAV functions while in motion.
http://www.beatsonicusa.com/beatsonic-nvk-01.html
Please pm me for a special CL price.
Thanks!
__________________
Old 02-24-14, 11:31 AM
  #39
Lavrishevo
Lavrishevo's Avatar
$140.00 ++ so you don't have to spend 1 second with your finger is obnoxious. Maybe for $40.00 but otherwise the price is ridiculous.
Old 02-24-14, 04:20 PM
  #40
Tom57
Tom57's Avatar
I didn't pay $140 so I don't have to spend 1 second with a finger - I bought a digital audio interface for the audio capability that has an additional feature which overrides the "I Agree" button. You can't simply bypass the "I agree" annoyance with 5.1 version or later. I know there are other products that function similarly / separately / differently. MML is digital audio all-in-one. VaisTech is a CL product sponsor as well.
Old 02-24-14, 05:08 PM
  #41
KING
KING's Avatar
I agree. $140 is ridiculous, even $40 is too much.
I thought there would be a homemade hack.
But paying that type of money for some wire isn't worth it.
As Vais is a sponsor of CL, what is the price we get for the device?
Old 02-26-14, 09:21 AM
  #42
StanVanDam
StanVanDam's Avatar
To allow in-motion typing on the LS430 nav system, go to the Nav ECU (trunk passenger side), cut N4-5 (VSS - vehicle speed sensor, YEL/RED in 2002, VIOLET in 2005+) and use a 2-conductor cable (ie. speaker wire) to connect 2 separate wires to each of the cut ends. Don't use a thick gauge cable because it will be harder to tuck it underneath carpets/trim when running into the cabin. I used 20ga RadioShack speaker wire.
Remove the trunk trim and run the cable into the cabin, and then attach a SPST switch whereever you find convenient. I ran mine along the driver side of the car, above the pedals, and around to the center armrest. I have a switch that sits snug in between the seat and the center console.
If that doesn't work, you'll have to remove the front nav unit and cut the VIOLET/WHITE wire on the M4 connector. This is pin 5 on 2002, pin 25 on 2005.
On my 2002, I've done the front nav unit VIO/WHT wire cut, the rear unit switch N4-5 switch, and the front unit parking brake signal grounding (LT GRN wire).
Refer to thread https://www.clublexus.com/forums/ls4...e-driving.html
Old 02-26-14, 10:01 AM
  #43
Gene01
Gene01's Avatar
Thanks, Stan! Very good information.
Old 02-26-14, 10:49 AM
  #44
jasonson
jasonson's Avatar
Thanks for the no BS video, Airtime
Old 05-19-17, 10:14 AM
  #45
Hagar
Hagar's Avatar
Originally Posted by DavidinCT
Are you saying there is a software mod to to a disc to override ? Or are you saying I can take a disc from a 05-06 LS and create a new disc with some of the old files from a older disc to override ? Could I also copy over the new maps and replace them on a older DVD and have updated maps ?
It would be nice not to have to go though that process every time I start up the car, also it would be nice to see the radio messages with out stopping....
Any clue ?
Are you saying there is a software mod to to a disc to override?
What he said. I just don't see how a disk GPS upgrade would change what I would think would be a hardware mod? So how does Lexus get into the screen IF they have upgraded your GPS disk? Follow?
I cannot override my Nav unit (v15.1 U30) so maybe there's some credence to this, I just can't see how.
Oh and to the guy who made the video, great job wish it worked for me.
Quick Reply: LS430 navigation bypass/unlock?
