Navigation Proglem after installing Air Ride Controller
Old 06-28-06, 10:30 AM
solarea100
solarea100's Avatar
Default Navigation Proglem after installing Air Ride Controller
Good day….
I have not been able to find much on Nav problems on the LS430. My navigation screen keeps on freezing and I need to re-start the car in order to fix the problem.
The only thing I’ve done is install a Datasystem Air Ride Controller, which works fine.
Any thoughts??
Old 06-29-06, 08:40 AM
FLIPPU
FLIPPU's Avatar
Originally Posted by solarea100
Good day….
Any thoughts??
I just installed this controller as well and my NAV works just fine... Did you get the correct harness for the YEAR/MODEL fof your car?? I know when installing the harness, it is pretty tight in there..make sure that each clip (3 Total) on the ECU is tight..they made a clicking sound when plugged in.
You may have a loose connection somewhere.
Mike
Old 06-29-06, 10:38 AM
solarea100
solarea100's Avatar
I will. I am also thinking that it may be heat related. I've been parking outside and the problem is more pronounced in the afternoon. Mornings are fine.
Old 06-29-06, 01:08 PM
GammaLex
GammaLex's Avatar
Just to make sure its the controller why dont you unplug for a bit to see if the nave continues to freeze up.
Old 06-30-06, 10:26 AM
solarea100
solarea100's Avatar
Yeah, that's the next step....I've been trying to park in the cool as much as possible and it is not freezing up as much, might be heat related....I'm thinking the DVD player is getting too hot as it sits in the trunk.
Turismo
10-27-17 06:28 PM
frotiss
10-26-11 08:21 AM
sunsolaris
10-05-08 09:02 AM
jbbreeden
03-01-08 04:56 AM
Quick Reply: Navigation Proglem after installing Air Ride Controller
