Hood shock/strut fix (The Mother thread)
Old 01-29-11, 08:55 AM
  #151
98LSUK
98LSUK's Avatar
Originally Posted by silos5
hey guys!! I have a question about hood struts. On mine ´98 I still have OEM and they suck. I went to a shop and found some. The problem is I cant choose which one to buy: they have different Newtons - 120N, 200N and 300N. I know the hood is heavy but I dont want to have any problem with closing it. And I want my hood to stay up also! Anyone can give an advice on which on to buy??
ps: I´m from europe, so buying ebay struts from US is more expensive for me.
hi
the correct force is 400N for car made between 95-2000 (mark 3 and 4)
hope this helps
Old 01-30-11, 06:09 AM
  #152
silos5
silos5's Avatar
thanks for the reply.
Went to a shop today, they didnt have 400N struts, so I bought 500N. Now the hood opens good and stays up. Closing is not difficult.
Got both struts for 25EUR (~35$).
Old 01-30-11, 08:41 PM
  #153
willcrets
willcrets's Avatar
I obtained three sets of hood lift struts including one set for my Lexus from <http://www.autopartsbylou.com/>....I was very satisfied with the price, quality, and service.
Old 09-01-11, 10:54 AM
  #154
butcher
butcher's Avatar
will this work?
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3718wt_1165
I have a 94 ls400...and I got hit in the head when my hood dropped>>ouch!!
Old 10-13-11, 10:09 AM
  #155
94Celsior
94Celsior's Avatar
Default Front hood shocks - aftermarket replacements?
My front hood shocks are totally done. Is there anyone who has replaced these before that might know where I could find a set or possibly some aftermarket ones that would fit the bill?
For now I find myself using a broomstick when I'm under there
Thanks!
Old 10-13-11, 10:52 AM
  #156
Cope
Cope's Avatar
I just had mine replace 2 weeks ago. Bought them at Auto Zone. Approx $40 to $45 with tax. Goodyear installed them during an oil change. $20.00 for both. About 1/2 what dealer charged. Took 10min.
Old 10-13-11, 10:56 AM
  #157
BrittonJ85
BrittonJ85's Avatar
I have and could not find the correct replacement at any of my local parts store and did not want to go to the dealer so I just went to the junk yard and grabbed them off one of the LS400 there. It was easy to install, all I did was unbolt the 2 bolts. Also before I had replaced my hood shocks I used some vise grip pliers to help hold the hood up if I was doing any work under the hood. But check out the following for more information.
Hood Struts by Asin for 1st & 2nd Generation LS
Aftermarket Hood Struts
Hood Strut
Hood shocks cheap on ebay?
<moderator edit - links all merged into this master thread>
Thanks!
Old 10-13-11, 10:06 PM
  #158
trukn1
NELOC Mod
trukn1's Avatar
Using aftermarket hood struts is just fine for the budget minded. I ordered some from Ebay about 4 years ago, and they are JUST needing to be replaced now (leaking). Is REALLY simple to do. Prop the hood, 10 mm open ended wrench on both ends, uninstall, re-install and you're done. There are PLENTY of reputitable sellers on Ebay that have them and require NO adjustment whatsoever(direct bolt on)
If you can find some in working order, your local boneyard is also another option; provided they are in working order.
--Cope - Which one's did you buy from Autozone?? If you bought the Mighty Lift C95029 struts they have been know to eventually cause a bowing of the hood. This is because they are meant for the hatch section of SUV's and Wagons, not the hood and are UBER strong. Happened to me awhile ago.
Old 10-14-11, 08:38 AM
  #159
Cope
Cope's Avatar
Mighty Lift rings a bell with me. I will check. Thanks trukn1 I will keep a watch on them
Old 10-14-11, 09:15 PM
  #160
iamviolet
iamviolet's Avatar
i use this..
and it always fits and works..lol
http://www.amazon.com/Lisle-44870-Go...8652068&sr=8-4
Old 10-17-11, 06:28 PM
  #161
beeronus
beeronus's Avatar
Originally Posted by iamviolet
i use this..
yea i use that as well
Old 10-19-11, 03:31 AM
  #162
Rollaboy
Rollaboy's Avatar
There have been many issues with aftermarket struts bending the hood. So be very carefull with saving money on this. search the forum for more info on wich brands you should avoid.
I bought the original from sewellparts.com with clublexus discount its $82 each. Heres the part numbers for my 91 LS.
right 5344059015
left 5345059015
normal price in store is $134 each.
Old 10-19-11, 05:04 AM
  #163
Lesley1
Lesley1's Avatar
I got mine at autozone.com
They were delivered right to my doorstep.
$26.00 each.
approx 10-15 minute job on install.
Be safe and have a helper.
Old 01-05-12, 07:32 PM
  #164
BigLexx
BigLexx's Avatar
Mine are toast too! I think i'ma give RockAuto a try. they carry Strong arm and RhinoPAC hood struts.
Old 01-06-12, 06:43 AM
  #165
McPierson
McPierson's Avatar
Here is what I used on my 99:
Ebay struts for $40 shipped. They are "Tuff Support Gas Springs 612200 replaces 4566" They were perfect came with bolt in ball mounts that fit, were the perfect length, and wern't too hard to lower the hood.
Quick Reply: Hood shock/strut fix (The Mother thread)
