Hood shock/strut fix (The Mother thread)
Old 01-27-17, 01:10 AM
  #196
bradland
bradland's Avatar
Smile
+1 on Sachs SG329035
Just did my '99 in approx 10 min. The trick, as many here have already stated, is to remove the old strut/ lift by taking out the ball stud while the strut is still attached. I propped my hood up for support while I removed them with a 12mm wrench. The Sachs lifts come with new studs that use a 13mm wrench. Once the new studs are in attach the struts using the little clips on each end. My hood is perfect again!
Old 01-27-17, 07:52 AM
  #197
Banshee365
Banshee365's Avatar
My experience with OEM Toyota struts is that the ball isn't designed to be removed from the socket so there isn't much of a choice than unscrewing the ball while the strut is still attached.
Old 01-29-17, 07:34 PM
  #198
Stretch21
Stretch21's Avatar
Thanks! been wanting to fix mine forever now. these hoods are no joke
Old 06-16-17, 01:26 PM
  #199
dashan
dashan's Avatar
Default Replace the hood struts, cost $19
No longer need the hood wood support.
Old 06-16-17, 01:32 PM
  #200
dashan
dashan's Avatar
Very strong arms. Made in China, and from Amazon.
Old 06-18-17, 06:38 PM
  #201
westopill
westopill's Avatar
Would the struts you bought work on a 94 LS? I looked on Amazon but didn't find a pair cheaper than $30.
Old 06-18-17, 07:36 PM
  #202
dashan
dashan's Avatar
https://www.amazon.com/Vepagoo-Lexus-1998-2000-Charged-Support/dp/B01EWJET38/ref=sr_1_1?ie=UTF8&qid=1497839768&sr=8-1&keywords=Vepagoo+Lexus+LS400+1998-2000+Gas+Charged https://www.amazon.com/Vepagoo-Lexus-1998-2000-Charged-Support/dp/B01EWJET38/ref=sr_1_1?ie=UTF8&qid=1497839768&sr=8-1&keywords=Vepagoo+Lexus+LS400+1998-2000+Gas+Charged
Old 06-18-17, 07:40 PM
  #203
dashan
dashan's Avatar
It might need some modifications to get it fit in a 94.
Old 10-15-18, 07:57 PM
  #204
wahaus
wahaus's Avatar
Default Hood struts. For 1991 LS
With the weather turning colder, it’s time to replace my hood struts. Anything special I need to know? Left and right the same? Any brands to avoid? Thanks.
Old 10-23-18, 03:50 PM
  #205
jckevin
jckevin's Avatar
Default Hood struts
I bought new struts for my '91 on Parts Geek. Worked fine.
1992 Lexus LS400 Hood Strut - W0133-1607903 First Equipment Quality - $20.48
Qty Ordered: 2, Qty Shipped: 2
Old 10-23-18, 10:36 PM
  #206
RA40
Super Moderator
RA40's Avatar
Some of the old links are broken now. This method works to extract the ball joint and pull the snap ring on the inside for the 2-LS's. Will have to research to see if this applies to the 1-LS.
Old 10-23-18, 10:57 PM
  #207
JonnyO78
JonnyO78's Avatar
These look like 90-94 with replacement studs.
Amazon Amazon
​​​​​​​I'll let y'all know how they work out.
RCsGX
GX - 1st Gen (2004-2009)
11-08-13 04:53 PM
amy011079
Suspension and Brakes
08-26-09 09:42 AM
megamarine
SC- 1st Gen (1992-2000)
14
04-13-09 12:10 AM
mtparker18
09-20-08 04:14 PM
Dx3
10-04-06 10:42 AM
Quick Reply: Hood shock/strut fix (The Mother thread)
