Hood shock/strut fix (The Mother thread)
Old 04-15-12, 11:03 PM
  #166
RocketmAAn
RocketmAAn's Avatar
Vise grips on a strut that is not going to be replaced is unadvisable. Scratches will start to wear out the seal.
Old 04-16-12, 08:54 AM
  #167
cndnate
cndnate's Avatar
If the strut is blown already then so what?
If that worried you can wrap a cloth on the piston before clamping it
Old 04-16-12, 06:53 PM
  #168
BobN54
BobN54's Avatar
I replaced my hood struts with Strongarm #4566; $19.14 each from Amazon, with free shipping since I have Prime. The strength seems to be perfect. No way is the hood going to bend.
Now, if there was just an aftermarket replacement for the trunk struts...
Old 05-01-12, 07:45 PM
  #169
SpencerT
SpencerT's Avatar
Strongarm makes trunk supports for us too
http://www.ebay.com/itm/2-REAR-TRUNK...item256fbd34fb
not sure if thats strongarm though. but i know i saw them when I got my hood supports
Old 02-02-13, 10:32 PM
  #170
ls400geek
ls400geek's Avatar
I bought a pair of complete hood shocks for $37 shipped off ebay from partsavenue--they work really well.. Just unbolted the old ones, threw them away and bolted on the new ones (really fast). Stiff to close, opens itself with a slight push upwards. Within 1/2 cm the length of the stock ones which seems to be working fine.
Old 03-15-13, 03:38 PM
  #171
J053Ph
J053Ph's Avatar
Just ordered the strongman hood lifts from ebay today.
http://www.ebay.com/itm/370766258582...84.m1497.l2649
Will definitely post a quick review when I receive the hood lifts.
Old 04-08-13, 09:34 AM
  #172
j e f f
j e f f's Avatar
Just received the Strongarm 4566's for my 97 LS.
#12 open end spanner to remove the old Tokicos(one is actually pouring oil every time it closes).
#11 to replace with the new mounts.
Took less than 10 minutes per side and now I can get rid of the pvc pipe I've been using as a hood prop!
Old 04-20-13, 04:43 PM
  #173
Jasbmo
Jasbmo's Avatar
I just picked up these hood struts from Amazon for my '98:
"LEXUS LS400 1998 1999 2000 Front Hood Gas Lift Supports, Struts, Shocks, Dampers, Qty (2) L & R Strong Arm 6301"
Link:
LEXUS LS400 1998 1999 2000 Front Hood Gas Lift Supports, Struts, Shocks, Dampers, Qty (2) L & R Strong Arm 6301 : Amazon.com : Automotive LEXUS LS400 1998 1999 2000 Front Hood Gas Lift Supports, Struts, Shocks, Dampers, Qty (2) L & R Strong Arm 6301 : Amazon.com : Automotive
$50 with shipping and they work great!! I'm very happy with these...tensions is great, fit is great, easy installation.
Old 05-19-13, 09:26 PM
  #174
diamondave
diamondave's Avatar
well i am happy to announce i replaced my hood supports yesterday. I used a brand called turbo lift which i picked up at the local Napa auto parts. They were the only ones in town that had them in stock. everyone else had to order them. I took a look at this thread and read a few post about "grinding this" or altering that. With these you just unbolt them using a 12mm wrench at the hood and at the fender and they come with new threaded ***** which thread right in which i believe they are 3/8. Then the new hood shocks snap right on. Picked these up for about 20 bucks a piece.
Old 05-19-13, 10:38 PM
  #175
dengman
dengman's Avatar
i got some strong arm ones off of ebay.
Old 08-01-13, 08:26 AM
  #176
dan200w
dan200w's Avatar
The first modification I made to my "new" 1995 LS 400 was to replace the hood pistons. I used the StrongArm 4566 that I purchased from Amazon. It took me about 25 minutes. Easy and work well.
Old 09-26-13, 05:54 PM
  #177
TexFinn
TexFinn's Avatar
Bought a pair of Sachs SG229032 from RockAuto for $33.xx shipped. Installed today and they work great.
Old 09-26-13, 08:06 PM
  #178
JZCHAOS
JZCHAOS's Avatar
Got mine from the Junk yard!!!!
Old 12-16-13, 06:43 PM
  #179
myway
myway's Avatar
My hood wasn't staying up on my LS400 so I ordered two Strongarm struts from Amazon at $19.12 each. I replaced the driver's side first and to my surprise, the hood stayed up. When I detached the passenger side strut, the hood wood not stay up. Guess I got lucky as only one strut went bad and the other was still good.
Old 12-31-13, 09:11 PM
  #180
Michael
Michael's Avatar
Default Hood Strut
I got mine from ebay, a seller name Parts Avenue. I bought this back in August, 2011. The parts came with lifetime warranty and paid only $26.62 + $8.47(shipping) = $35.08 for a pair.
Installation took only few minutes (not sure of this but recall no problem what so ever) and installed better than OEM. I have been using the strut for 2 years now and performing flawlessly. I hope it lasts but has the warranty coverage. Just recently I inquired about the warranty coverage since the ebay only keeps my purchase record for only 3 years.
I did some research prior to the purchase and some struct will have too high pressure that it bend hood. This one is like tailor made. Pressure is just right.
I sound like I may be related to the seller but I am not. This is one product I am very pleased with, so far. Just hope their warranty is as good.
Quick Reply: Hood shock/strut fix (The Mother thread)
