How to change third brake light (bulb)?
Old 10-14-03, 06:03 PM
seanl
seanl's Avatar
Default How to change third brake light (bulb)?
One of the bulbs on my CHMSL (center high mounted stop light) is burned out. Does anyone know how to properly remove this unit? I can't tell if it can be accessed from the trunk by removing the liner or if it removes from inside the car.
Thanks.
Old 10-14-03, 08:26 PM
LexLS
LexLS's Avatar
Post
Open up your manual, the answer will be in there .
Old 10-14-03, 10:03 PM
seanl
seanl's Avatar
The Owner's Manual simply states bulb type and wattage. Recommends taking it to the dealer for bulb changing.
I don't own the shop manual yet, I need to order one from Iron Toad ASAP.
Can you elaborate a bit?
Old 10-14-03, 10:51 PM
LexLS
LexLS's Avatar
Post
Man, it sucks that your manual is that vague. Take your car to the dealer to change a bulb? Gimma a brake!!! If you can take a picture, I'll take a pic tomorrow and post more.
Old 10-15-03, 12:29 PM
LexLS
LexLS's Avatar
Post
If your rear deck looks like mine then this may help...Pull up on the cover near the arrows, there are just two clips that hold mine in, they pop right out. If your rear deck doesn't look similar to mine just throughly inspect it, these plastic pieces are usually just held in place with clips.
Attached Thumbnails How to change third brake light (bulb)?-brakelampcover.jpg
Old 10-15-03, 02:12 PM
seanl
seanl's Avatar
Thanks Earl. My setup is a bit different, the center speaker grille cover is SEPARATE from the CHMSL. I tried tugging on it gently, but to no avail. You are probably right though, I just need to pull a bit harder.
Thanks, I'll check it out tonight, I didn't drive the car today, weather was really nice so I drove the Cobra to work.
Old 10-15-03, 05:26 PM
Lexkost
Lexkost's Avatar
Use a screwdriver and pry up on the backend (not the lense side ) be careful and it will lift up.
Old 10-15-03, 06:38 PM
seanl
seanl's Avatar
I just finished changing out the bulbs---I took earl's advice and firmly lifted up on the ends with my fingers and the entire assembly popped out. There's a quick disconnect fitting that allows the assy. to be easily removed from the car too. I replaced both bulbs with sylvania long lifes, total cost $4.49.
Thanks anyway Lexkost, I would have tried your method if I'd read this before fixing it.
Best Regards,
alextv
Maintenance
10-05-11 07:12 PM
Searles945
07-22-09 09:34 AM
Lexs400
10-16-03 02:36 PM
rukarims
03-14-03 09:07 PM
bouellet
11-09-02 08:49 PM
Quick Reply: How to change third brake light (bulb)?
