Cooling fan elimination mod.
Old 09-30-03, 09:46 AM
Rice
Rice's Avatar
Default Cooling fan elimination mod.
I'd like to try this mod on my car, a 97 LS400.
I noticed that in the summer, the stock belt driven cooling fan eats up a lot of power when the fan clutch engages.
I'm thinking to remove the stock fan and replace it with 1 or 2 electric fans attached to the inside of the radiator.
The two problems that I anticipate are:
1 - finding the right aftermarket shroud with fans built in
2 - setting up the electric fans to turn on/off when coolant reaches the right temperature.
If anyone has any info on this please share it.
Thanks.
Old 09-30-03, 02:56 PM
Lexkost
Lexkost's Avatar
Get yourself a Summit Racing Catalog they have what you are looking for( you will have to adapt the parts to work on a Lex)....their web site is not very good but you can get their 800 number off the site to order a catalog .
Old 09-30-03, 06:03 PM
350z
350z's Avatar
I removed the main cooling fan on my LS. I immediately noticed a gain in hp. All I have are the two accessory cooling fans. I live in Arizona where the temp easily exceeds 110 and have had no problems and the accessory fans rarely kick in .
Old 10-01-03, 06:20 AM
Rice
Rice's Avatar
That's incredible!!
Have you ever been stuck in traffic?
I live in NY, where it rarely gets any hotter than 95.
Last summer my car began to overheat in traffic. I know that the fan is not the solution to all the problems, but still, I can imagine what would have happened if I did not have it.
Anyway, simply removing the stock fan and not replacing it with something else is not the solution for me.
As the mater of fact, I would advise you to either do what I am planning to do, or to put back your stock fan. If you ever get stuck in traffic for any period of time, your engine is toast!
Old 10-01-03, 08:12 AM
350z
350z's Avatar
every so often i hit some traffic. the temp guage stays dead center. maybe my LS is bulletproof. hah!
Old 10-01-03, 11:36 AM
RA40
Super Moderator
RA40's Avatar
Has anyone tried one of the lightweight flex type fans? The clutch is a reasonably heavy unit and with all that mass spinning, I would think lightening would help.
additude
09-04-17 04:43 PM
skytechja
GS - 1st Gen (1993-1997)
10-10-16 01:43 PM
ancdmd
03-19-12 08:08 PM
BBriBro
Performance & Maintenance
01-07-09 07:15 PM
'95_sc300
04-25-08 03:33 PM
Quick Reply: Cooling fan elimination mod.
