clicking/popping sounds
Old 09-09-03, 09:49 PM
persian451
persian451's Avatar
Default clicking/popping sounds
I get this noticable clicking/popping sounds when the brakes are pressed and the car is turning in the process.. it comes from the front section of the car.. could it be a bad axle or just brakes?
Old 09-10-03, 12:07 AM
jlopez
jlopez's Avatar
Default It's the Calipers making that noise
I had the same problem on my 98 LS400
Once I took to get serviced at the dealer - they gave me a copy of a bulletin for the "known clicking" notice that comes when you turn at slow speeds for most Models and Years from 1998-2001
You have to get the "Grease Points" lubed on the Calipers I believe. You might want to get this checked when you are getting you car serviced for other things.
If you want to get these point lubed individually, I can cost you a pretty penny.
Old 09-10-03, 08:18 AM
persian451
persian451's Avatar
so there are specific grease points on my calipers that need lubing?
Old 09-22-03, 04:49 AM
jlopez
jlopez's Avatar
Default Not too sure what points...
I have that document in my Serivice Car Records. I don't have that with me right now. But there can only be so many points you can lube on Brake Calipers right?
I think they are 2 points on each caliper that would need to be lubed.
peasodos
06-23-17 12:36 PM
Jbthompson
07-07-11 02:53 PM
MIA2GS
Suspension and Brakes
05-20-11 06:43 AM
vert310
13
04-30-09 05:18 PM
rtk7
11-14-07 04:52 PM
Quick Reply: clicking/popping sounds
