Suspension spring discussions (The Mother Thread)
Old 02-11-12, 07:00 AM
  #346
nap
nap's Avatar
i must be looking in the wrong places then only i cant fiend eney thing for the ls400,i had to order my springs from the US.dont no how long they will take.
Old 02-13-12, 07:33 PM
  #347
MyRolla
MyRolla's Avatar
try searching by your chassis code
Old 03-18-12, 07:39 PM
  #348
xinkid
xinkid's Avatar
Default difference between 97 and 98 stock front springs
Hi,
I found different part numbers for 97 and 98 front springs.
front spring
1997 4813150070
1998 4813150100
http://lexus.sewellparts.com/oem-cat...S400-1997.html
http://lexus.sewellparts.com/oem-cat...S400-1998.html
I posted more details in this thread where I am looking for 98 stock springs.
https://www.clublexus.com/forums/ls4...ml#post7096080
Would anyone in the know kindly inform me of what is the difference between 97 and 98 stock front springs?
Old 03-19-12, 12:59 AM
  #349
PureDrifter
BahHumBug
PureDrifter's Avatar
probably just a minor difference in spring rate to cope with the weight changes from the revision in '98.
will they interchange? yes.
will the difference change the ride? possibly, unknown.
Old 04-01-12, 08:02 PM
  #350
rome99LS
rome99LS's Avatar
Default heated springs vs lowering springs
Has anyone heated their springs and is the ride still decent? I'm thinkin about lowering the Ls this week.
Wat are good lowering springs that's not that expensive?
Old 04-01-12, 08:44 PM
  #351
j2b4o
j2b4o's Avatar
I think the h&r's are only like 350$ or less. That's not alot IMO and its a reputable brand with a decent history.
Old 04-01-12, 08:47 PM
  #352
PureDrifter
BahHumBug
heated springs are a beyond ghetto mod that compromises ride and safety. buy some lowering springs please.....
this will only be funny for another 10 minutes lol.
Old 04-01-12, 09:17 PM
  #353
RA40
Super Moderator
RA40's Avatar
Heated... From a simple metallurgy standpoint, that will ruin the spring temper and potentially cause the coil to shear/crack under load. If the spring cracks while driving and you lose control, the resulting aftermath will not be good. There is very little control as far as precise lowering that way. Don't do it.
Plenty of proper lowering springs available. By the time you replace the struts and springs, the least expensive Megans are about the same price. Go that way and be assured your car is lowered right.
Old 04-01-12, 09:46 PM
  #354
radiokilla
radiokilla's Avatar
If you love your car, you would NOT heat the springs. It is always worth it to save up for quality parts than to settle for something less. Doesn't your car deserve the best?
Old 04-01-12, 10:30 PM
  #355
west709
west709's Avatar
i hear good things about tanabe df210 springs. they are not too exspensive
Old 04-01-12, 10:44 PM
  #356
Tac1sc
Tac1sc's Avatar
Dont do it, you dont even have to buy lowering springs brand new. Look for used ones and have peace of mind.
Old 04-02-12, 12:28 AM
  #357
try2fndmrk
try2fndmrk's Avatar
Stay away from heated springs!!
Old 04-02-12, 05:09 AM
  #358
rome99LS
rome99LS's Avatar
Damn ok...ill start lookin for springs. I do love my car to death and I do want it tobe safe still...so h&r are around $350...Wat about others??
Old 04-02-12, 11:55 AM
  #359
RA40
Super Moderator
RA40's Avatar
Those H&R's are about the best that are still readily available. If your current shocks have some miles on them, when doing this swap, it is suggested to have fresh shocks put in. If you want better handling, that leaves you Bistein at $120 each or the KYB GR2's at a bit less. Factor in $200 to install and $75 alignment. See, you can buy Megans.
Old 04-03-12, 03:39 PM
  #360
SpencerT
SpencerT's Avatar
find some tanabe df210 off of ebay or a classified on here.
$250 MAXIMUM. will lower your car a good bit and still feels decent.
I got mine off here for 150.
a great investment. and the previous owner asked to buy them back they are so good.
Quick Reply: Suspension spring discussions (The Mother Thread)
