Suspension spring discussions (The Mother Thread)
Old 05-12-08, 11:29 AM
  #196
skybluecrx
skybluecrx's Avatar
I have done research and I know the Df210 are the only ones available, someone told me about the Gf210 so i thought I would throw it in there. My original plan was to get coils but the prices are up there for a decent set.
Old 05-12-08, 02:55 PM
  #197
steveski
steveski's Avatar
I spent hundreds on H&R springs with Bilstein HD struts - I would never do it again especailly since now there are many coilovers to choose from. If all you want is a drop then DF210's are fine. If you want a drop plus adjustability then obviously coilovers are the way to go. I wish I had bought them.
Old 05-12-08, 11:03 PM
  #198
slamgrayls
slamgrayls's Avatar
Default Anybody Cut Tanabe Dropsprings Post Pix!!!
Want To Know What Is The Drop Height When U Cut Ur Springs Lmk...
Old 05-12-08, 11:12 PM
  #199
PureDrifter
BahHumBug
PureDrifter's Avatar
cut springs are for people who dont know wtf they're doing and are too cheap to buy proper coilovers....
the only time to cut springs is when there is NO OTHER OPTION AVAILABLE, as in no springs or coilovers are made.....
Old 05-12-08, 11:14 PM
  #200
Nano-V8
Nano-V8's Avatar
i recently had to transfer my tanabes fron one car to the other and while i was doing it, i saw the grinder right there and well...ive been happy with the tanabes but ive always wanted the rear just a lil bit lower. like 1/2 inch. and i always here bad things about cutting springs. but i cut a bit anyway. only i was a lil b**ch about it and only cut half a coil on the rear springs. i didnt want to risk my ride being really bouncy and ruining the springs. other than that, i dont kno much about cutting the springs.
Old 05-13-08, 01:42 AM
  #201
DIY LS400
DIY LS400's Avatar
Cut springs have a tendency to fall off the lower spring perch. FTL!
Old 05-13-08, 07:25 AM
  #202
steveski
steveski's Avatar
Not to mention shorter springs will blow struts even faster since the inner strut portion still moves the same distance. Even if you trim bump stops to the bare minimum I think you will be disappointed in how the ride and their longevity.
DF210's are the shortest still made to my knoweldge.
Old 05-13-08, 07:54 AM
  #203
zokustyle
zokustyle's Avatar
if you're considering cutting springs, wave goodbye to your ride quality and shocks.
the remedy to blowing shocks when cutting springs is short stroke shocks. they can handle the much lower travel of the suspension.
i've run cut springs on the last two cars i've had, with no problems, other than really stiff and bouncy, once the shocks blew.
so warn girls before they get in.
Old 05-13-08, 08:00 AM
  #204
LiCelsior
Retired
LiCelsior's Avatar
i think 19psi cut his DF210 springs, not really that sure but i know he had cut springs.
Old 05-13-08, 08:15 AM
  #205
slamgrayls
slamgrayls's Avatar
thanx................people got some pix slammed with stock wheels
Old 05-13-08, 08:16 AM
  #206
JBrewster
JBrewster's Avatar
Ghettofabulous
Old 05-13-08, 08:37 AM
  #207
LiCelsior
Retired
LiCelsior's Avatar
here was 19psi's springs that are now sold.
https://www.clublexus.com/forums/sho...d.php?t=332353
Old 05-13-08, 11:37 AM
  #208
jcrome04
jcrome04's Avatar
Cut springs are for ricers. i would never cut springs personally.
I agree with PD, I could understand it if there was NO product made ANYWHERE.
Try to find coilovers.
Old 05-13-08, 12:12 PM
  #209
RA40
Super Moderator
RA40's Avatar
It is quite imprecise because you don't often know the spring rates. Cutting them you'll not know what ride qualities you'll get once installed. Spotting the hack jobs are easy. Adjustable coils/bags go down the street smooth or a touch of firmness. Guys on springs usually have 1 finger gap or there abouts and are still smooth. The stiff bouncy rides...hack job. It may look fine sitting in a parking lot but driving it...
It is also a sure way to test how good your suspension bushings hold up to little to no suspension travel. All those little rubber parts that support something heavy like engine, tranny, control arm...those parts become shock absorbers for the constant jarring ride. Nothing like a stiff bouncy ride to test how well your car body is welded together also. Once it begins squeaking and creaking...
Attached Thumbnails Suspension spring discussions (The Mother Thread)-simpsons_nelson_haha2.jpg
Old 05-13-08, 01:13 PM
  #210
Rocan
Rocan's Avatar
as the other posts say... DONT DO IT. save up your cash for actual springs... not all the replacement parts youll need after cutting them
Quick Reply: Suspension spring discussions (The Mother Thread)
