brake warning light...
for those you guys that have that problem.. does it mess with your cruise control also??....my brake warning lights is also on.. and i notice that when that was on... my cruise control doesnt work anymore... so.. hopefully someone on here will help me fix that problem.. thanks
Brake Warning Light
I had the same problem a while ago on my '90 LS. Apparently, there is a safety feature that will not allow the cruise control to work if the brake fluid level drops below a certain point. This, of course, will also trip the warning light. Turns out I had a leaky brake hose. You might want to check your fluid level first.
Im not sure if you are getting the rear brake light failure light,
or the parking brake light. I had the light failure, so I can tell
you about that. It will cause a short on your instrument cluster,
also when you press the brakes, the transmission shifts into
neutral. I dont think the cruise works either. If it is an older LS,
chase the brake light wires, mine were very brittle and just broke
from the FL heat. Good luck!
-R
-R
