coolant tank question
Old 08-12-03, 08:50 PM
persian451
persian451's Avatar
Default coolant tank question
I noticed in this hot weather in San Diego, that whenever I work the car hard driving it passed 4500 rpm - redline, after popping the hood, i see that teh coolant resevoir bubbles out a little coolant..
After a couple weeks you can notice the dried up coolant that turns all white around the area?
Am i making sense here? The Temp guage has always read normal... is this a possible problem with the temperature regulator or whatever its called
Old 08-12-03, 09:36 PM
SharpLS-96
SharpLS-96's Avatar
Actually, that's normal for it to overflow a bit if you drive your car extremely hard then shut it off immediately. Your thermostat is working just fine so don't worry about it. Just keep an eye on it because you might have to add antifreeze if you continue driving in that style. I would suggest not to redline it because you are doing damage that will eventually catch up to you.
Old 08-13-03, 12:38 AM
persian451
persian451's Avatar
i c... thats what i figured.. but you never know about that thermostat... thanks for the help
Old 08-13-03, 06:15 AM
tn52
tn52's Avatar
Talking No, it is not normal.
You got a micro crack in your coolant reservoir. You can either buy a new reservoir or fix it with some special plastic glue. If you decide to glue or patch it, you better do it now since the crack is still small. It's a fairly common problem on 1st gen LS.
Old 08-13-03, 09:20 AM
persian451
persian451's Avatar
how do i find the crack? there is a small opening on top fo the resevoir by the cap... i guess its for releasing coolant when overheating
Old 08-13-03, 09:37 AM
tn52
tn52's Avatar
Default Where?
Check those spots that got the white dry coolant. Usually the cracks are right under the white goo mess. You need to clean the spots real good then check them under bright sun light for cracks. Look carefully. Most of them are even smaller than a hair line crack that make you wonder how could they leak? The answer is "pressure & expansion" - think about the high + hot pressure in the plastic container...
peterls
24
09-29-19 02:41 PM
Ron81
06-25-17 04:33 PM
adreano17
01-25-13 06:53 AM
azari
01-28-03 05:46 PM
Quick Reply: coolant tank question
