No more overheating... A/C Fan works
Old 08-03-03, 03:37 PM
Lexozz
Lexozz's Avatar
Default No more overheating... A/C Fan works
I finally fixed the problem. I made numerous requests to find out where the A/C thermal switch is located. It's been over a year. My thermal sensor is good. The problem was a blown fuse under the driver's headlight. Thanks to my Lex partner in crime "nextlevelcoupe", he had a similar problem, but he had to change his thermal sensor which is located at the bottom of the radiator on the driver's side. I never knew there was an extra fuse box located there until we started discussing the situation, then something hit me. I started tearing sh$%t apart and found it.
Old 08-03-03, 03:42 PM
Lexozz
Lexozz's Avatar
Check these pics out, location of the fuses. Air Sus (red) far left, RDI fan no 1 and RDI fan no 2.
Attached Thumbnails No more overheating...  A/C Fan works-ac-fan-and-air-sus-fuses.jpg
jack90 (11-26-22)
Old 08-03-03, 03:48 PM
Lexozz
Lexozz's Avatar
Fuse cover. RDI Fan No.2 was blown.
Attached Thumbnails No more overheating...  A/C Fan works-ac-fan-and-air-sus-fuse-cover.jpg
Old 08-03-03, 03:56 PM
Lexozz
Lexozz's Avatar
A/C Fan
Attached Thumbnails No more overheating...  A/C Fan works-ac-fan.jpg
Old 08-03-03, 04:02 PM
Lexozz
Lexozz's Avatar
Last one. OEM fuse part# 90987-03001, and replacement aftermarket fuse from AutoZone $19.99
Attached Thumbnails No more overheating...  A/C Fan works-ac-fan-fuse.jpg
Old 08-03-03, 04:05 PM
nextlevelcoupe
nextlevelcoupe's Avatar
invaluable info!!
Old 02-11-14, 06:41 AM
MattLS400
MattLS400's Avatar
This is some invaluable info. I guess this is a good way to verify whether or not my Hydraullic Fan is stock or whether or not It came with an Electric Fan and the previous owner just swapped an entire Hydro Fan.
96Celsior (UCF21) (1UZ-FE)
Old 06-05-20, 11:52 PM
JohnAndic
JohnAndic's Avatar
Could this be why I never seen my AC fan Turn on in my 97? I don't think this car ever had AIR SUSPENSION
Old 06-06-20, 02:58 AM
Sin1UZFE
Sin1UZFE's Avatar
my 99 didn't have any at all. Replaced both those two on right and now turns on
Old 06-06-20, 08:09 AM
JohnAndic
JohnAndic's Avatar
Is there supposed to be only 2 fuses or whatever they are in there? Never seen a picture of it with 4 modules in there.....
Old 06-06-20, 09:22 AM
Sin1UZFE
Sin1UZFE's Avatar
I've seen one with the air suspension in there
Old 06-06-20, 06:29 PM
JohnAndic
JohnAndic's Avatar
From what I can tell, some of the older cars 90-94 had the FAN NO3 Module to run an older type of fan, could be also because they have 2 fans in the front there. Then if you have AIRSUS you'd have that module also. In mine there are no wires going to either the AIRSUS or the FAN NO3. Probably most if not all 97 won't have that FAN NO 3 module.
JettCRX
RX - 1st Gen (1999-2003)
18
05-31-22 07:46 PM
bigking
05-30-17 11:41 AM
akeem444
10-20-15 09:58 PM
ROKLEX
01-20-12 06:47 AM
ozzie
GS - 1st Gen (1993-1997)
06-05-08 09:15 PM
Quick Reply: No more overheating... A/C Fan works
