TOM's exhaust vs. stock on LS430
Old 07-23-03, 03:55 PM
LS007
LS007's Avatar
Default TOM's exhaust vs. stock on LS430
TOM's has a barrel exhaust system for 01+ LS430's. Do you think it will make the LS sound any different outside or inside the cabin? If so in what way (bubble or grawl sound)? I'd like to keep the sound non-intrusive inside of course, but it could be a bit more aggrisive sounding outside.
Thanks in advanced...
Old 07-23-03, 11:33 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
You know, any aftermarket exhaust will give you grawl with or without silencers. Here is what I am gonna use. I would go with the whole JIC setup if I were you.
http://www.jic-magic.com/Exhaust/noispipe/noisypipe.htm
I am sure you lill like it. Another electronic Bondish toy
Old 07-23-03, 11:47 PM
JBrady
JBrady's Avatar
VidNav,
YES... that system will be MUCH louder both inside and outside. What are your goals in changing exhaust? More power or just a bit more sound?
Retro, that valve tube is over 3" inches. Where are you planning on placing it? It could be functional if placed in the correct location but I am afraid it is not going to help your power. Obviously it will not when closed but open that 3.15" pipe is going to slow velocity considerably and probably reduce low/mid range power noticeably.
Old 07-23-03, 11:57 PM
JBrady
JBrady's Avatar
OK, looks like the Toms exhaust for the LS430 is a conventional baffled muffler design (possibly large case straight through) The Oval tips are probably designed to fit an aftermarket rear bumper. The barrel design is straight through and probably much louder.
http://l-tunedparts.com/html/partsor...400_LS430.html
Seriously, for $1800 bucks you aren't getting much more than 2 muffler and fancy tips that will not even fit your stock bodywork.
A MUCH better solution to slightly stronger sounding exhaust would be to simply install a couple quality turbo style mufflers. A pair of good stainless mufflers are around $200 and installation should be $100-200.
ZiPPyRCF
RC F (2015-present)
75
12-21-15 09:57 PM
horent135
Performance & Maintenance
11-20-08 12:56 AM
joncruz1
09-24-07 10:15 AM
912inc
08-24-07 06:09 AM
Ramon
Performance
02-11-06 09:11 AM
Quick Reply: TOM's exhaust vs. stock on LS430
