What the going prices for maintainence...
Old 06-24-03, 02:28 AM
Bj(CA)
Bj(CA)'s Avatar
Default What the going prices for maintainence...
for the 400's?? meaning full tune up, full timing belt service.. i just bought a 97 coach edition with 108,000 miles . i dont know if he had any major service done. iam thinking to just off the bat to do a tranny, brake, coolant flush, new diff oil.
thanks
Bj
Old 06-24-03, 03:39 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
BJ,
Go to your local Lexus dealer and have them run a service history report for you in the service department. If any service was done at the dealer, they'll be able to tell you what & when (date and mileage) it was performed on your LS based on the VIN.
I did this on my LS before I bought it and found that they'd replaced the front brakes, had done major services, etc.
Old 06-24-03, 05:37 PM
gs400998
gs400998's Avatar
Default Re: What the going prices for maintainence...
thanks
Bj
If 90K service is not done on your LS then you are looking at a major service. Lexus dealer here charges $700 for 90K mile service. Timeing belt and water pump is another $850.
Old 06-25-03, 10:57 PM
Pagong
Pagong's Avatar
Timing belt, water pump, tensioner, cam seals, gaskets, caps, rotors, wires $1485.xx with labor
This is through my best friend who is ASE certified. Going back for the power steering pump, alternator, starter, brakes, the infamous ball joints upfront, tranny fluid , differential fluid...looking to spend about $1500.xx more.
Oil change was free, radiator flush was free.
Old 06-26-03, 12:37 AM
Bj(CA)
Bj(CA)'s Avatar
Default got some prices
ok. went to the local lex dealer dto get an oil change $39.95, ans to pull up the serice history. well it seems the last owner did to the 60 or 90K. the dealer charges $998 for the 60K and $750 for the timing belt, no water pump. i wonder if the ls is really that hard to work on like my twin turbo z??? can i trust a local shop???
later
bj
Old 06-26-03, 11:16 AM
Pagong
Pagong's Avatar
The thing is that when you change your timing belt, they have to take soo much crap out of the engine that its always a good idea to replace what can be replaced when its already opened up. Like with the timing belt, the water pump is right there and if you have the 1st Gen LS might as well replace the water pump. And with that the seals have to be replaced, gaskets and so forth.
As for trusting a local shop, unless you know the mechanic personally. If you dont it is up to you to decide. I would rather pay my friend the $78/hour labor charges than the dealers $100+/hour charges just for the timing belt.
I was quoted at the dealer for a 90k service of $485, this is only the parts, labor he said takes about 10-15 hours....
Here's the breakdown on what was done to my car:
Timing belt
idler pulley low
idler pulley high
water pump
cam seal
crank seal
coolant flush
thermostat and gasket
ignition cap
ignition rotor
labor was 11 hours mainly because of the water pump placement.
total $1429.86
460LSinTN
Maintenance
12-03-12 04:40 PM
430drvr
06-29-12 04:34 PM
roumieh200
12-21-10 09:12 AM
sphereman
11-02-02 01:59 AM
xsohaib
12-24-01 02:23 AM
Quick Reply: What the going prices for maintainence...
