95 LS400, rough idle
Old 06-13-03, 10:33 PM
Losiho
Losiho's Avatar
Default 95 LS400, rough idle
Recently my 1995 LS400 has a very rough idle. This only happens when the transmission is in Drive with the a/c off. The revs are barely above zero, and the tacho needle shakes, along with the steering wheel. Otherwise, the are no other problems. It idles fine in Park or Neutral, and with the a/c on, and drive well once on the move.
Has anyone got any suggestions ? Would resetting the ECU help at all ?
Old 06-14-03, 08:18 PM
GA400
GA400's Avatar
Post TPS maybe?
Resetting the ECU wouldn't hurt.
A fairly common problem on the LS400 and the GS400 is the throttle position sensor. Search results here https://www.clublexus.com/forums/sea...der=descending
Of course there are the other usual suspects of worn/fouled spark plugs, spark plug wires, dirty air filter, fuel injector issues, etc.
Good Luck and let us know what you find out.
Old 06-15-03, 09:00 PM
Losiho
Losiho's Avatar
Thanks for the advice and the link GA400, unfortunately resetting the ECU didn't help. Hopefully it'll be diagnosed at service.
Stereorob
01-15-23 09:32 PM
SimonJ
04-29-19 08:00 AM
Ninjam
11-24-14 10:00 PM
LANcr3w
66
10-28-13 11:01 PM
maxgee
06-26-10 11:01 AM
Quick Reply: 95 LS400, rough idle
