anyone have a pic of P/s pump?
Old 06-10-03, 05:24 PM
Lvangundy
Guest
Posts: n/a
Default anyone have a pic of P/s pump?
I'm thinking my P/S pump might be leaking if it's the part thats conencted to the rack and pinion on the driver side.
If not t han it' the rack and pinion...I think that's a $500 repair job.
Old 06-11-03, 06:36 AM
dbullen
dbullen's Avatar
I replaced my PS pump last Janurary. Bought a used pump on ebay for $125 and had lexus install it for about 2.5 hrs labour. I still have the old pump around somewhere. If I can find it i'll take a pic for you tonight. If it is the pump make sure it gets fixed as I believe they leak right onto the alternator. I've heard a few stories of people have to replace both the PS pump and Alternator at the same time.
Old 06-11-03, 08:16 AM
Rice
Rice's Avatar
Default P>S> pump leaking
Make sure that it is really the pump that is leaking.
More often than not, it is one of the two P.S. hoses that is actually leaking. It is usually the High Pressure hose that sends fluid from the pump to the R&P.
Old 06-11-03, 08:32 AM
Lvangundy
Guest
Posts: n/a
Thanks for the inut -
I really need to see the picture to tell what part is leaking.
if you are under the car it's on the left side to the left of the cat. It's connected to the rack and pinion and has two hoses/steel hoses or something where fluid is leaking. It's vertically angled up towards the steering columnl ..I think..
Old 06-11-03, 09:43 AM
LexLS
LexLS's Avatar
Post
I think I have the same problem on mine, fluid leaking on the driver's side under the car. The PS pump is located in the engine area. I have a feeling it's one of the hoses that is leaking as Rice said and not the pump itself because the pump looks fine. Does it make lot's of noise when you turn the steering wheel? Anyway I'm taking my car in as soon as I get a shipment parts so I'll get this fixed as well.
Here is a picture of it: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2418542430
Old 06-22-03, 06:58 PM
juddly
juddly's Avatar
Default Go to eBay for images
Hi:
If you want to see what the PS pump looks like, go to eBay, where several of these are listed fro sale.
I seach eBay using this search criteria:
http://cq-search.ebay.com/search/sea...d&BasicSearch=
Last time I looked there were several PS pumps for sale, new and reconditioned.
My PS pump leaked, and I installed a low mileage used unit for cheap, and it works fine.
TTYL,
Bill
Old 06-23-03, 09:12 AM
thedon67
thedon67's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2420765932
I just posted these pictures this morning. Finally replaced my old pump with a new one. Thought somebody might want to buy the old one and use the rebuild kit to fix it up. That way they could leave their current one in the car until ready to be switched.
Good luck with yours.
Don
Sin1UZFE
IS - 1st Gen (2001-2005)
05-21-19 07:42 AM
iridebmx
Performance & Maintenance
04-04-14 05:27 PM
Quick Reply: anyone have a pic of P/s pump?
