What does your temp gauge display?
Old 05-18-03, 10:09 PM
LexLS
LexLS's Avatar
Post What does your temp gauge display?
Ok I would like to just get an overview here. Ever since I bought my car my temp gauge has never gone above the 2/6 mark in my pic. I know it is within normal range but I still wonder...so what does your LS show? It is at 2/6 when it's warmed up, here's the pic so you know what I'm talking about.
Earl!
Old 05-19-03, 01:06 AM
retrodrive
Search Function Inc.
retrodrive's Avatar
Mine lingers in the middle but I drive like a maniac.
Old 05-19-03, 01:10 AM
brian3268
brian3268's Avatar
Abcedefghij
Old 05-19-03, 06:56 AM
jasonmo
jasonmo's Avatar
mine usually lingers right around the middle, even when I'm driving crazy, or very normal. It seems weird that yours is that low. Every car I've had I've always seen the temp gauge around is always around the middle.
Old 05-19-03, 07:33 AM
Lvangundy
Guest
Posts: n/a
Mine is always in the middle and rarely goes above the middle point. Only when I drive hard and for along distance.
I've NEVER seen an LS at that point before. Is there some kind of aftermarket thermostat? (my only guess?)
BTW - Is your gauge cluster messed up? the lower left sidel ooks like it's been burned or something.
Old 05-19-03, 10:26 AM
ychachad
ychachad's Avatar
Default Re: What does your temp gauge display?
Earl!
Mine is exactly half way at operating temp. Either your gauge is broken, or if the temperature is the actual temperature, and your engine is running at such a low temp all the time, then I bet you your emissions are sky high, and your fuel economy is terrible. A richer engine runs at lower temps. Check the thermostat, may even check the Oxygen sensors and your MAF sensor. My guess is that the gauge has gone bad. I have never seen an engine run at such low temps. Only higher.
Old 05-19-03, 10:56 AM
LexLS
LexLS's Avatar
Post
I suspected that it should be running at the halfway point. I'm definitely going to get this taken care of soon. I was going to bring it to my mechanic soon anyway, man I'm not looking forward to the price tag for all the repairs coming up . Thanks for the input guys.
Earl!
Old 05-19-03, 10:59 AM
LexLS
LexLS's Avatar
Post
Oh yeah and the cluster is fine, just a bad picture, I took it at night.
Old 05-19-03, 11:05 AM
ychachad
ychachad's Avatar
Earl!
If your fuel economy is normal, and your emmissions are normal, just ignore the temp gauge. Don't worry about it.
Old 05-19-03, 03:14 PM
SharpLS-96
SharpLS-96's Avatar
Bad thermostat, replace it.
Old 05-20-03, 08:14 AM
mlevk
mlevk's Avatar
My 91 is on the 2nd line always ,
I had a new water pump and T-stat
installed when I did my T-belt about
2 years ago. and I remained the same after that.
Old 12-11-03, 01:13 PM
lspower
lspower's Avatar
anyone buy a trd thermostat? i want one... i think they are 76$ or so accord to trd's website, but they list it for the toyota crown that also has the 1uz?
thanks
ryan
Old 12-11-03, 03:33 PM
Shaffer
Shaffer's Avatar
My 90 LS400 also runs at very low temperature. It is usually slightly above the 2nd line. Even in town, I have seen it right at the 2nd line, but there are times that it is between the 2nd and 3rd line. Just below the 3rd line is the highest I have seen my temp gauge. One good thing is that I have heard a cooler running engine will typically last longer.
Interesting about the comment about the economy and "richness" of the engine. Upon startup in the morning, my car puts out a "gassy" smelling smoke. It smells almost exactly like gasoline. Then it goes away after a couple of minutes. I have also noticed low economy. I have about 120 miles on my odometer since fill-up and if I recall, it is just below the 1/2 way mark. Is this poor economy?
Thanks.
Old 12-11-03, 06:58 PM
GA400
GA400's Avatar
Post mine is just above the 2nd line too
Mine is at about the same point yours is, Earl, maybe just a touch higher - never up to halfway. It was there before the water pump / timing belt / thermostat swap, and it is at the same point now. My car runs a bit rich at first, but I still get about 19 mpg in town, 25 or so on the highway, so economy looks great to me.
Old 12-11-03, 07:09 PM
Lexkost
Lexkost's Avatar
Talking about the temp. on my LS it never makes it to the half way point on the gauge even on 100 plus days..................and I have never seen the electric fan running....
Quick Reply: What does your temp gauge display?
