Annoying Clunk Sound- Strut Bar (The Mother thread)
Old 04-02-13, 06:56 PM
  #256
TaffyK20si
TaffyK20si's Avatar
Yeah I've been dreading the install under load. May just use my jack on the spindle if there is room. If not I'll have to break out some boards or something.
About the clocking, I just now thought about it, but I should be able to replicate how the new ones go it by comparing to how the old ones sit in the arm. Duh lol
Is there a certain part that needs to be marked for the caster alignment or is it pretty much a no brainer once you're down there?
Old 04-02-13, 08:36 PM
  #257
Eds98LS
Eds98LS's Avatar
That should work! I'm sure the tech's at my toyo dealer did the same.
From memory...the metal washer looking deal (alignment piece) on the arm sits in a slot and that slot has notches at the 3 and 9 o'clock positions. I just drew a line from the notch in, then when I reinstalled that metal thing I matched the black lines with the notches. They generally stay put once you tighten the nut (or bolt, can't recall!)
Old 04-02-13, 11:01 PM
  #258
PureDrifter
BahHumBug
PureDrifter's Avatar
caster will have to be reset after as the new bushings will deflect less than the old. (meaning yes, you will need to realign.)
the "bump" or extra "notch" of rubber should be 90* to the arm, pointing DOWN once the arm is installed. (as per FSM SA-34)
Old 04-03-13, 10:05 AM
  #259
TaffyK20si
TaffyK20si's Avatar
Thanks for the help guys! About to take off work for the day and get this done. Taking the strut rods to my friend with a machine shop to get the bushings pressed out and in.
And yes, alignment will be a must. I just want to make sure I've solved my issue before I have it aligned. May look at lower ball joint next if problem persists.
Old 04-03-13, 10:51 PM
  #260
TaffyK20si
TaffyK20si's Avatar
OH WOW! Favorite thing I've done to my car yet. All my shutters are gone, noises gone, I even feel like my tires don't rub my fender liners as bad. Love it!
Old 07-09-13, 05:50 PM
  #261
j5ive
j5ive's Avatar
Hi all,
New owner of a 96 LS400. Can someone help take a best guess as to which component I need to replace?
* Heavy clunking sound when entering (and sometimes exiting) driveways, and hitting speed bumps.
* When braking hard to a stop, I can feel the front end shimmy left to right.
* When taking a turn (like a right turn at intersection) with a bit of speed, the car pushes out a step in the middle of the turn.
Thanks for your help.
**** Update
Just an update on my car for those who may have similar symptoms. My mechanic took the car to his front end guy. The strut rod bushings were shot. The lower ball joints were going, but no where as bad. Both items were replaced on both sides of the car and a front alignment done. I've been told the symptoms are all gone. (told because I haven't driven the car since. But my wife seems happy with the changes.)
Last edited by j5ive; 10-02-13 at 10:56 PM. Reason: update after fix to help others
Old 07-09-13, 09:18 PM
  #262
RA40
Super Moderator
RA40's Avatar
The first in this suspension is the strut bar bushings. Any other residual issues then go to sway bar bushings, tie rods, upper and lower ball joints and control arms. Depends on miles and how long the neglected issues have been let go. If this car has not had any suspension service, my list for a one shot deal to start:
Strut bar bushings
Tie rod ends
Lower ball joints
Your mechanic will be able to test the other areas when the parts are removed.
Old 07-11-13, 11:24 AM
  #263
Lavrishevo
Lavrishevo's Avatar
Sway bar links, which I don't hear mentioned often, are another one that can cause popping sounds.
Old 07-12-13, 12:24 PM
  #264
j5ive
j5ive's Avatar
Thanks guys. Will check strut bar and sway bar bushings first. Hope it's just one of these as they'd be easier and cheaper to replace. On one of the previous cars I've owned, I had sway bar bushings go and it made s clunk as well.
Old 07-12-13, 05:46 PM
  #265
j2b4o
j2b4o's Avatar
Originally Posted by j5ive
Hi all,
I had almost the same symptoms and I also had some slight wandering during highway driving. Mine is a first gen so the strut bar is different but the main culprit for all the clunking and front end movement on mine was the upper ball joints. The wheel could move about 1/4" in and out freely with the car sitting on the ground.
Just mentioning it so you don't overlook the upper ball joint while diagnosing.
Old 07-13-13, 01:33 AM
  #266
LScowboyLS
LScowboyLS's Avatar
I would say upper control arms (some folks call this component an upper ball joint) would be the second most likely item to go bad in an LS400 front end after the strut bar bushings.
Old 08-07-13, 02:51 PM
  #267
ninja757
ninja757's Avatar
im planning to change my strut rod bushings, any tips on how to press in and out the bushings? is the 3 jaw puller good? or should i buy the entire rod with bushings?
also on my outter tie rod bushing, there seems to be some grease leaking. is this normal? the bushing itself looks fine no cracks just a little leaking out when you squeeze it.
thanks.
Old 08-07-13, 05:21 PM
  #268
LScowboyLS
LScowboyLS's Avatar
a 3 jaw puller?? - I use a hydraulic press
just take it to your local machine shop and spend $10 for these services, that is what they do, and they are good at it! - just make sure to bring the page from the factory service manual that shows the correct orientation of the bushing, so they get it aligned at 0 degrees - that diagram has been posted on Club Lexus before, find it and print it out to take with you for them to use.
the outer tie rods are cheap, even the real Toyota ones, I would just replace them and enjoy the new tighter steering as a result!
Old 08-08-13, 04:07 PM
  #269
ninja757
ninja757's Avatar
ok i will check the local shops. i have the file on the orientation.
ok i got you. thanks alot. should i change the ball joint too? it looks fine though.
Old 08-15-13, 11:23 PM
  #270
usoff89
usoff89's Avatar
I was looking at the "strut bar cushion" on sewell's site. They have them for $199.74 each. This seems extreme for this type of part, or am I wrong? Thats a little over $400 for two bushings!
Quick Reply: Annoying Clunk Sound- Strut Bar (The Mother thread)
