NEED HELP - Coilovers
Old 05-18-15, 03:14 PM
Auxive
Auxive's Avatar
Default NEED HELP - Coilovers
---Deleted---
Last edited by Auxive; 11-28-18 at 07:16 AM. Reason: Information is no longer relevant or useful to the forum
Old 05-18-15, 05:02 PM
RugbyDad
RugbyDad's Avatar
You won't benefit from a camber adjustment plate on coilovers if negative camber is what you want. Not on the ls400 thanks to the double wishbone config. You can get a few degrees out of the factory suspension (the drop will contribute to it naturally), but if you want more than that you're gonna need to invest in some ncrca's or some aftermarket (nagisa) arms which can get ridiculously expensive.
Old 05-18-15, 06:18 PM
Auxive
Auxive's Avatar
I'm looking to get LESS negative camber, pretty much trying to adjust it to stock. I was just wondering if there was any set of coilovers with ANY type of adjustment to get as close to stock as possible.
Old 05-18-15, 07:16 PM
RA40
Super Moderator
RA40's Avatar
The adjustable mounts are common with McPhearson type systems. The LS's multi-link wishbone doesn't allow this type of adjustment in the shock assembly. How low are you planning to set the car at?
Old 05-18-15, 07:32 PM
Auxive
Auxive's Avatar
Ahh bummer... I'm looking to go no lower than 3 inches, somewhere between 2 and 3 to be exact. I put a LOT of miles on my LS400 daily, so I'm looking to get as close to stock camber as possible so I won't be needing to replace tyres ever so often.
Old 05-18-15, 09:03 PM
RA40
Super Moderator
RA40's Avatar
At 2-3" drop the camber isn't extreme. Mine is a few ticks shy of 3" in front and the camber is -1.5. The rear at 2.25" drop is -1.25. The summer tires go 40-44K miles before replacement. That's not even letting it get to the wear bar either. Key is getting the toe settings right when aligning the car.
INCLINEDI
Suspension and Brakes
02-01-12 08:12 AM
whitecel
08-26-10 11:52 AM
wagomaniac
SC400 / 300 Classifieds
03-03-10 09:58 PM
mgtype
01-08-10 08:51 PM
NCDUB
03-24-09 02:40 PM
Quick Reply: NEED HELP - Coilovers
