Questions and part numbers - 98 LS400
Old 05-06-15, 07:37 AM
SonicC
SonicC's Avatar
Default Questions and part numbers - 98 LS400
Hello,
So yesterday I became an owner of a 98 Lexus LS400. I bought it from an older guy who had owned it since 2001, but the car came with some extras and needs some work. And by extras, I mean a few CEL codes.
I'm getting the following: P1349, P0300, P0156, P1346 and I also have the VSC/OFF warning on.
After doing some research, everything seems to point to the OCV - so I figure that's a good starting point. I want to note, however, that the car runs and idles very smooth - despite all these error codes - so I assume they're not as severe as some people have experienced.
As a VW owner I've got plenty of experience working under the hood so I'll tackle this and see what comes out of it. The CEL codes seem to indicate the OCV in Bank 1 is bad. I assume Bank 1 means left hand side (driver's side)?
Doing further research, I found the following part number: 15340-50011
Can someone confirm this is the correct part number for the left hand side OCV? Also, what are some good places to get this part from (other than the dealer)?
Bonus question: looking into what kind of suspension these cars came with, it looks like some of them had adjustable/air suspension? Was this only on certain years?
I apologize for such a lengthy thread...or novel.
Old 05-06-15, 08:32 AM
SonicC
SonicC's Avatar
Found one on eBay that claims to be genuine Toyota part: http://www.ebay.com/itm/TOYOTA-LEXUS...-/251825597862
Old 05-06-15, 05:41 PM
SonicC
SonicC's Avatar
No one?
Old 05-06-15, 06:02 PM
sha4000
sha4000's Avatar
This is the one you need. I just changed mine a couple weeks ago.
http://www.ebay.com/itm/231450919003?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 05-06-15, 07:27 PM
SonicC
SonicC's Avatar
Toyota Lexus Factory Cam Timing Oil Control Valve 15340 0F010 15678 46020 | eBay
Looks like the only difference is that it includes the filter?
in the few articles I've seen, they just replace the solenoid? I assume this just goes on the end of the OCV?
Old 05-07-15, 05:46 AM
sha4000
sha4000's Avatar
Just go with the cheaper one. The filter is useless unless your going to take the valve cover and bearing cap off.
Old 05-07-15, 06:13 AM
billydpowe
billydpowe's Avatar
I didnt replace mine, I just took it out and cleaned it real good and the chamber also and put it back in and it has continued working for over 3 years....
Attached Thumbnails Questions and part numbers - 98 LS400-ocv-oil-controll-valvee.jpg   Questions and part numbers - 98 LS400-oil-control-valve.jpg   Questions and part numbers - 98 LS400-ocv-loc.jpg
Old 05-07-15, 07:01 AM
SonicC
SonicC's Avatar
Hm, I'll have to try this...since removal doesn't seem to be all that complicated. If it doesn't fix the issue then I'll just order new one. What did you clean it with?
I guess if the above doesn't work, then I'll order the solenoid and filter and replace the valve cover gasket while I'm at it.
Thanks for the help, guys, much appreciated.
Anyone know the answer regarding suspension?
Old 05-07-15, 11:50 AM
sha4000
sha4000's Avatar
It came with air suspension in all years I believe.
Old 05-07-15, 07:34 PM
SonicC
SonicC's Avatar
Finally had a chance to take the wheel off and take a look...it definitely looks like standard coil and shock suspension.
While trying to get the rest of the wheels, I found out that two of them are using the security lugs and I don't have the key does anyone know whether Lexus used the same key on all cars or they have different variations? I assume dealership should be able to remove these?
Otherwise...
Nah...just kidding.
Old 05-08-15, 06:22 AM
Legender
Legender's Avatar
I just had a similar problem on my 98... locking lugs were stripped out. Fortunately Sears is still around and sells a Craftsman tool designed to solve this problem. Sockets with grooves that cut into the offending lug nut and remove it...either standard lug nut or locking nut.
Looks a bit like this:
http://www.sears.com/access-tool-aet...2&blockType=G2
But mine had a cloth case and 4 sockets and was about 1/2 that price.
Old 05-08-15, 06:31 AM
SonicC
SonicC's Avatar
You're a life saver...I completely forgot about these. I was about to go all McGuyver over this and hammer on an old socket
Old 05-08-15, 07:19 AM
billydpowe
billydpowe's Avatar
[QUOTE=SonicC;9029797]Hm, I'll have to try this...since removal doesn't seem to be all that complicated. If it doesn't fix the issue then I'll just order new one. What did you clean it with?
carburetor cleaner and a small rag clipped in a pair of mechanical fingers..
HA, I thought 3 years but it has been 5 years look https://www.clublexus.com/forums/ls4...lights-on.html
Old 05-08-15, 07:52 AM
SonicC
SonicC's Avatar
Definitely going to try this. Did you also clean the valve/solenoid or just the filter?
Old 05-08-15, 10:30 AM
billydpowe
billydpowe's Avatar
no the filter/screen is in a different location, I just cleaned the VALVE to where it had the original snapping action, VERY good and the chamber it slid into.. also cleaned it til it came out without any black...
Quick Reply: Questions and part numbers - 98 LS400
