Broken headlight
Old 04-11-15, 04:10 PM
dantampa
dantampa's Avatar
Just replaced the headlight unit and everything seems to be functioning fine. However, we noticed a total of three bulbs and we cannot figure out the purpose of one of them. It is a very small bulb that sticks through the HID housing. This bulb is missing (bird took it out) but everything still seems to be functioning fine without it (HID lowbeam, non-HID highbeam, and the DRL). So what is this mystery third bulb for?
Old 04-11-15, 10:23 PM
sha4000
sha4000's Avatar
I forget the exact name but its a small park/accessory bulb that's on when the headlights are off.
Old 04-14-15, 08:00 PM
dantampa
dantampa's Avatar
Update as requested:
Installed the new headlight unit over the weekend. Took about 20-30 minutes total (with the help of a very mechanically-inclined friend). The fit seems to be very good and there were no real issues swapping out the headlight unit. It did not come with a ballast unit or bulbs. However, the ballast unit and bulbs from the old headlight unit were easily swapped to the new headlight unit and disconnecting and reconnecting the wires from the car to the new headlight unit were not a problem either.
So far, I would definitely recommend this particular headlight unit replacement part.
Now the only problem is that the new headlight looks so good compared to the other headlight (which is probably original to the car -- 16 years old) that I'm really thinking about spending another $200 to replace it as well (as opposed to just having it professionally polished, etc).
Old 04-15-15, 03:07 AM
qewani1
qewani1's Avatar
you can change the lens only with aftermarket headlights lens.
check my old post below
https://www.clublexus.com/forums/ls4...os-inside.html
Old 04-15-15, 06:29 AM
sha4000
sha4000's Avatar
I doubt the OP wants to go that route.
Old 04-15-15, 05:48 PM
dantampa
dantampa's Avatar
Would you mind elaborating a bit more on your thoughts regarding replacing just the lens?
Old 04-15-15, 06:31 PM
sha4000
sha4000's Avatar
Go to the link he posted. He created a DIY.
Old 05-14-15, 04:07 PM
sha4000
sha4000's Avatar
Based on recommendations here on the forum and from a friend, I'm probably going to order the following unit in the next hour or so:
HID Xenon Headlight Headlamp RH Right Passenger Side for 98 00 Lexus LS400 | eBay
In going to five these headlights a try also. I have new corner lights and it looks weird with the old dull headlights. I polished them with the kit that Kansas suggested but now they are so again, plus I don't feel like having to keep polishing them.
tarheel49
04-09-18 11:07 AM
Kenorme
GS - 1st Gen (1993-1997)
09-24-17 08:46 AM
Jcorwin
05-17-15 09:40 PM
jkayca
ES - 5th Gen (2007-2012)
04-13-15 12:20 PM
smmart
GX - 1st Gen (2004-2009)
06-09-08 07:05 AM
Quick Reply: Broken headlight
