96 LS 400 - Camber and control arms
Old 03-31-15, 12:15 PM
MattLS400
MattLS400's Avatar
Default 96 LS 400 - Camber and control arms
Good day,
I am currently experiencing a " drift " from the rear on my 96 LS400....It was previously only at high speeds, however it seems like it got worse and now its regardless of speed.
I went to the mechanic who check the allignment and saw that it was zero-point.
However, upon inspecting, he told me that id need to replace ( SEE photos) ;
2 Rear Camber Arms ( With connecting links )
2 Lower Control Arms
2 Spindle Bushings
My queries are;
1) Can I simply replace the bushings in these arms Instead of purchasing the arms in its entirety?
2) If no to the above, can someone please provide me with a link that sells these parts ?
3) If unable to provide a link, please provide a part number for my Rear LH and RH Camber arms
Attached Thumbnails 96 LS 400 - Camber and control arms-camber-and-control-arms.jpg   96 LS 400 - Camber and control arms-control-arms.jpg
Old 03-31-15, 12:32 PM
timmy0tool
timmy0tool's Avatar
pls read:
https://www.clublexus.com/forums/ls4...hich-ones.html
only certain bushings are replaceable.
Old 04-03-15, 01:20 PM
MattLS400
MattLS400's Avatar
Thanks for your reply.
Can you please indicate to me which bushings are replaceable ?
Attached Thumbnails 96 LS 400 - Camber and control arms-bushing-kit-needed.jpg
Old 04-03-15, 03:26 PM
timmy0tool
timmy0tool's Avatar
pretty much the ones circled in color in my pic are the replaceable ones. ADUS are the aftermarket part numbers for the parts.
Old 04-04-15, 09:18 AM
sha4000
sha4000's Avatar
I think Matt can't tell which bushings are which.I hope this thread is helpful.
https://www.clublexus.com/forums/ls4...-attached.html
Old 04-04-15, 01:14 PM
MattLS400
MattLS400's Avatar
correct me if im wrong
Attached Thumbnails 96 LS 400 - Camber and control arms-img_20150325_165518.jpgjjjjjjjjjjjjjjj.jpg
JDMV8
IS F (2008-2014)
31
07-21-21 05:46 AM
Behemoth7
07-26-18 02:07 PM
V8drummer
Suspension and Brakes
14
04-06-13 10:09 PM
Biggu
SC400 / 300 Classifieds
16
01-12-12 06:13 AM
Toastt
Performance & Maintenance
01-02-12 09:56 AM
Quick Reply: 96 LS 400 - Camber and control arms
