Lower glovebox removal....not so simple
OK I know this is suppose to be quick and easy so maybe I'm missing something. After opening the lower glove box door on my 95 LS, I removed the 3 screws, I also removed the lower cover underneath by pulling it straight out, now what? I know there is something still anchoring the box down but I can't find it and I don't want to force anything. Any suggestions and/or pics that will help? Thanks in advance.
there's 2 nuts that need to be removed
One behind the glove box on the left side, there's small cover plastic cover you need to remove to access it in the back of the glove box.
The other one is on the far right just under where the trim ends, you need to lower your head to look under the dash you will see it it's just where the door close.
hth
hth
hth
hth
