Engine Code 25
Old 03-01-15, 10:24 AM
frostls400
frostls400's Avatar
Default Engine Code 25
Lean condition if I researched it right. Some say O2 sensors but which ones? Should I just replace all 4 to be safe or do 2 then reset ECU?
Old 03-01-15, 10:51 AM
python
python's Avatar
front 2 sensors
Old 03-01-15, 02:26 PM
dicer
dicer's Avatar
Check and test.
Old 03-02-15, 02:46 PM
frostls400
frostls400's Avatar
Front two being upstream correct? And it is a simple resistance check for the O2 sensors right?
Old 03-03-15, 10:39 PM
oldskewel
oldskewel's Avatar
Yes, front two are upstream, before the catalytic converter.
A resistance check can tell you the resistance of the heater circuit, but that's not the whole story.
The full test involves accessing the OBD-like connector in the engine compartment, jumpering two pins together, and measuring the voltage at various engine RPM conditions. All spelled out in the manual. And I think there's at least one typo in the manual.
Old 03-03-15, 10:56 PM
qewani1
qewani1's Avatar
don't change sensors/parts before reading their data using a scanner to insure that they are failed to work!
massakill
Performance & Maintenance
11-03-18 08:06 PM
durec
02-10-11 05:49 PM
BriMcc
01-06-02 08:58 AM
Quick Reply: Engine Code 25
