New Lexus Owner
Old 02-28-15, 05:17 AM
javeiro
javeiro's Avatar
Default New Lexus Owner
Well I purchased my first lexus a couple of days ago, still getting used to everything, hope i have posted this is the right place, but wasn't sure what to search for ..... A quick question that may seem obvious to you, but just wonder what people make of the picture i have enclosed, should I leave it blanked off? Or connect it? It is to the right of the engine bay, seems like a breather of some sort? What is it? 1998 LS400 by the way. Thanks.
Attached Thumbnails New Lexus Owner-img_6278.jpg   New Lexus Owner-img_6271.jpg
Old 02-28-15, 06:12 AM
Yamae
Yamae's Avatar
It's a PCV line. Your engine is absorbing unfiltered air and exhausting blow-by gas depending on the engine phase and polluting both your engine and the air. Should be connected like this below.
Old 02-28-15, 08:44 PM
dicer
dicer's Avatar
And it is not venting out the bad gases and moisture in the crank case.
Old 03-01-15, 10:35 PM
qewani1
qewani1's Avatar
You have major vacuum leak!
Old 03-01-15, 10:44 PM
Yamae
Yamae's Avatar
I can see how your brain works.
Old 03-02-15, 01:43 AM
javeiro
javeiro's Avatar
Default Thanks
thanks for the replies! Why would this have been done? Any benefits?
Ive reinstalled it now. Looks like it was done recently, so no damage would have been caused i'm guessing? Cheers. James
Old 03-02-15, 02:07 AM
Yamae
Yamae's Avatar
You'd better ask it to the one who did it. I don't think it benefits you any. This is just my guess without checking the hose and the PCV valve but the line was not in a good condition or something like that. I once had a cracked hose and it caused intermittent strange sounds + high idle.
https://www.clublexus.com/forums/ls4...8-celsior.html
Old 03-02-15, 11:10 AM
timmy0tool
timmy0tool's Avatar
easy fix and glad you took yamae's advice! welcome and enjoy the site, you should learn a lot and start at the FAQ!
Old 03-02-15, 05:16 PM
javeiro
javeiro's Avatar
Thanks timmy0tool and Yamae, I reconnected it and its running fine, so will keep it that way! Great forum, still learning a lot about Lexus but so far very impressed!
Old 03-03-15, 07:01 AM
billydpowe
billydpowe's Avatar
it will be the best car you have ever had if you take care of it..
Old 03-08-15, 10:54 AM
javeiro
javeiro's Avatar
Default strange
just a quick question, but ever since I reconnected that hose to the PCV, I've noticed it smokes heavily on start, both cold and when hot, and under acceleration. Strange how this has happened since reconnecting but was fine before? The smoke is blue and i think it is oil. Checked coolant, oil etc and it is fine. Perhaps a bad PCV valve? Thanks.
bassil2022
02-08-10 07:25 AM
BottomsUp
Automotive Care & Detailing
10-08-06 08:19 PM
Pianoman72
09-22-03 08:57 PM
Garry
Maintenance
01-18-03 10:44 AM
Quick Reply: New Lexus Owner
