A/C & Clock display
Old 03-12-03, 12:37 PM
alanuk400
alanuk400's Avatar
Default A/C & Clock display
I can't read the digital display on the above, It lights up on startup but no digits. How do I get the panel off to check the bulbs behind.
Thanks, Alan
Old 03-12-03, 12:59 PM
pascualjr
pascualjr's Avatar
Check out the following link for removal instructions:
http://www.cureline.net/lex/audio/ho...io_removal.htm
Old 03-12-03, 04:27 PM
tenpointed
Banned
tenpointed's Avatar
There's really no point of taking the panel off since there aren't any light bulbs. It's an LED display and needs to be replaced. The same thing went out years ago on my old 95 LS400 on my radio & the entire head unit had to be replaced. More than likely you'll have to have the entire a/c display replaced. Maybe you can find one at a boneyard for cheap, unless your car is still under warranty.
Old 03-13-03, 11:37 AM
alanuk400
alanuk400's Avatar
Thanks, I will have a look in a breakers yard
Alan
Old 03-13-03, 11:41 AM
spxChrome
spxChrome's Avatar
Is the LCD blacked out or just no digits? There are 3 12 V bulbs that light the display? If it is burned out then the LCD needs replacing.
Old 03-14-03, 07:24 AM
alanuk400
alanuk400's Avatar
It lights up green & dims when I turn the headlights on, there is no digits on the display.
Alan
Old 03-14-03, 08:23 AM
spxChrome
spxChrome's Avatar
i would try replacing the bulbs first.
winter4w
03-23-15 06:50 AM
SLVRGS
01-10-06 03:12 PM
SC400MAN
11-18-04 12:36 AM
RedAE102
08-03-04 08:25 PM
Taka
SC- 1st Gen (1992-2000)
11-07-01 08:47 AM
Quick Reply: A/C & Clock display
