1991 LS400 Randomly won't start, just cranks and cranks?!?!
Old 01-22-15, 06:51 PM
dylanoj
dylanoj's Avatar
Question 1991 LS400 Randomly won't start, just cranks and cranks?!?!
Any ideas would be greatly appreciated,
I have 4 seemingly good ecu's and the problem persists.
Just put in a GOOD IAC valve.
It only does it randomly, I'll go to start it, it will start, then die, then I try to start it again, and it will just turn over forever and not start, then I let it wait a min, and try again and whilst it is turning over I'll pump the gas pedal slightly, but rapidly and it start sometimes. Sometimes it will just start if I give it a few min and come back... any ideas?
Old 01-22-15, 06:55 PM
sha4000
sha4000's Avatar
Is the check engine light on? If so get the codes read.
Old 01-23-15, 02:59 AM
dicer
dicer's Avatar
http://www.lexls.com/tutorials/intro/codereading.html
This is how you get the codes.
Old 01-23-15, 10:48 AM
dylanoj
dylanoj's Avatar
CEL is not on.
Old 01-23-15, 12:58 PM
sha4000
sha4000's Avatar
If it starts when pumping the pedal it might be something gas related. Maybe your pump is going out. Have you checked the air filter, distributor, coils, wires and plugs?
Old 01-23-15, 01:49 PM
timmy0tool
timmy0tool's Avatar
next is to check your fuel pump. do you hear it priming when initially turning the key? it should have a distinct hum.
Old 01-23-15, 04:48 PM
dicer
dicer's Avatar
Check fuel pressure.
metsno1
38
02-01-15 08:48 PM
ZGagnon
32
05-23-14 08:12 PM
jetskiwill
IS - 1st Gen (2001-2005)
12-02-13 11:55 AM
Joey97
05-15-12 11:21 AM
Im2gq4u
Performance & Maintenance
09-09-08 04:14 PM
Quick Reply: 1991 LS400 Randomly won't start, just cranks and cranks?!?!
