Caster arm rubbing on inner wheel
Old 01-20-15, 11:07 PM
OCLEX03
OCLEX03's Avatar
Default Caster arm rubbing on inner wheel
Hello guys, I have an issue with my 98 Ls400. It is all stock and I am having issues withe the driver side front caster arm rubbing against the inner stock wheel when the steering wheel is locked all the way to the right. Here are pictures of the caster arm rubbing on the inner wheel when full locked. It rubs and I can hear metal grinding against each other when I make a full right lock into a parking spot. Even grind my clip on balance weights as well. I had the caster arm bushing couple years ago, no issues.... Anyone have this issue? Any solutions?
Old 01-20-15, 11:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Get your car aligned by a competent shop, it should not have that much wheel angle at full lock.
LS430Lexus
01-18-20 11:47 PM
EthanS
04-26-19 10:53 AM
ancdmd
01-24-14 03:26 PM
aporozco
SC- 1st Gen (1992-2000)
12-03-10 12:14 AM
masagsxr
Suspension and Brakes
09-09-09 09:31 AM
Quick Reply: Caster arm rubbing on inner wheel
