93 ls400 ignition coils
Old 12-26-14, 12:42 PM
msweber97
msweber97's Avatar
Default 93 ls400 ignition coils
got 2 new coils for the car mounted the top side one since it was easy noticed no difference unplugged the drivers side one that is a pain to get to and hooked new coil up started the car and no more missing out. Does the coil need to be mounted down on the bracket to act as a ground or will i be able to tie the coil up out of the way and not mount it back down and be ok?
Old 12-26-14, 07:42 PM
msweber97
msweber97's Avatar
seems to run just fine without it mounted, once the nicer weather comes around then ill finally tear it apart and mount like it should be!
Old 12-26-14, 09:51 PM
sha4000
sha4000's Avatar
Just make sure it's stable. You don't want it bouncing around under there.
Old 12-27-14, 07:02 AM
msweber97
msweber97's Avatar
yes it is stable not going anywhere for sure!
Jknow82
04-14-18 07:50 PM
Katlexus
03-28-17 06:04 AM
gserrano80
05-31-16 03:50 PM
waseem3000
03-28-11 03:14 AM
91supra
IS - 1st Gen (2001-2005)
12-17-08 10:54 AM
Quick Reply: 93 ls400 ignition coils
