Changed an Oxygen Sensor - car running much better
Old 12-15-14, 08:36 PM
AHJ
AHJ's Avatar
Default Changed an Oxygen Sensor - car running much better
I was checking the fuel trims and the long term trims were running opposite.
Both bank 1 and bank 2 would idle at 10% but when I stepped on the bug under the gas pedal, bank 1 would go low (5%) and bank 2 would be climbing further up (15%).
There was no Diagnostic Code and the Check Engine Light wasn't on but since Amazon was delivering the Denso 234-4169 to my door for $50, I bought it and replaced bank 2. Bank 1 was replaced 2009.
Now bank 2 idles at 5% (bank 1 is still at 10%).
The car runs much better, has more power, the pinging sound while accelerating is gone. No smell of exhaust and no fumes in the cabin.
I am considering replacing Bank 1 also but its gone up to $80. Might be worth it but I will think about it for a couple of days. I want to see if it makes a difference in the gas consumption.
The sensor referred to is the Heated Oxygen Sensor 1/Upstream/pre-cat. Bank 1 on my Canadian LS400 96 is on the driver's side.
Attached Thumbnails Changed an Oxygen Sensor - car running much better-dsc_1068.jpg   Changed an Oxygen Sensor - car running much better-dsc_1071.jpg
Old 12-15-14, 10:04 PM
RA40
Super Moderator
RA40's Avatar
Good job. If the ECT sensor hasn't been changed, that will also be a part to consider.
Old 12-16-14, 10:52 AM
Sanpete
Sanpete's Avatar
Price is pretty low now:
Amazon.com: Denso 234-4169 Oxygen Sensor: Automotive Amazon.com: Denso 234-4169 Oxygen Sensor: Automotive
Old 12-16-14, 07:53 PM
AHJ
AHJ's Avatar
Thank you.
I got mine from the Canadian site. US sites tend to pile on import fees and then there's the exchange rate. so about CAD $64 which is still less than half the dealer price and about the same as the Canadian price now.
Its too late to be buying stuff off the internet.
The old sensor seems to be covered up with ashes.
alcez42
02-26-20 04:43 AM
eoph
IS F (2008-2014)
28
08-30-12 08:48 AM
cbones1979
RX - 1st Gen (1999-2003)
10-13-11 06:32 AM
wtdt
12-21-10 02:38 PM
hoonami
28
02-20-09 09:15 AM
Quick Reply: Changed an Oxygen Sensor - car running much better
