Transmission goes in reverse but not drive
Old 11-30-14, 09:50 PM
1Demarco1C
1Demarco1C's Avatar
Default Transmission goes in reverse but not drive
I'm new to this forum but I have a problem with my transmission. It will move fine in reverse but want move at all in d,2,3 or L. It also has a o0500 code what could be the problem I change the transmission filter 4 months ago
Old 11-30-14, 11:55 PM
dicer
dicer's Avatar
What year?
Old 12-01-14, 12:00 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
I think you mean P0500?
We need way more information than what you've provided before we can help, starting with the year of your chevy camaro.
Old 12-01-14, 12:18 AM
dicer
dicer's Avatar
P0500 speed sensor, or circuit instrument cluster or ECM
http://www.lextreme.com/Lexobdiicode.pdf
Old 12-01-14, 05:41 AM
1Demarco1C
1Demarco1C's Avatar
It's a 96 lexus ls400
Old 12-01-14, 07:20 AM
1Demarco1C
1Demarco1C's Avatar
You are right it's a p0500 code
Old 12-01-14, 12:12 PM
dicer
dicer's Avatar
And fluid level is fine? Does it go into gear when in forward D, L, 2.3 etc? A parking brake will hold better forward than in reverse.
Does it coast okay? Simple things first.
Worse case is the forward clutch is not working.
Old 12-01-14, 03:33 PM
1Demarco1C
1Demarco1C's Avatar
dicer, just got off from work today added some fluid to get it to the right level. The car goes into R,D,2,3, but when you put in L it acts like it's in neutral. To get it back in drive u have yo shift up to neutral then go to drive. I drove it around my block and it shift fine until you are at a stop then it goes into that neutral mode again then you have to do like above shift back to neutral gear then drive to get going again. I reset to code I'm going to drive it awhile to see if the code p0500 come back If so I'm going to change out the vss 'a'. What's your advise.
Old 12-02-14, 02:46 AM
dicer
dicer's Avatar
Vss would not stop it from going into gear, and you say it upshifts good. Sounds more like a shift linkage problem, unless they are all electric then a switch problem.
A good thing to do would have been to just drain the pan and remove it and change the filter screen, clean the pan and then add the fluid. While pan is off check shift linkage action if possible.
wmj259
10-25-18 08:33 AM
bluejay9i6
GX - 1st Gen (2003-2009)
03-26-17 10:17 AM
forplatina
03-18-17 10:27 AM
mikob
35
04-01-15 12:34 PM
hotdawwg
11-12-12 07:21 AM
Quick Reply: Transmission goes in reverse but not drive
