I need an armchair diag on this 90 LS
Old 11-28-14, 11:33 PM
HotTubTony
HotTubTony's Avatar
Default I need an armchair diag on this 90 LS
I'm thinking of buying this 90 LS400, as you can see in the ad, it has a few issues. What do you guys think the overheating issue might be and what I should be checking for?
http://grandrapids.craigslist.org/cto/4778865208.html
Originally Posted by 1990 Lexus ls 400
Car has some issues. It overheats and has no power steering also a oil leak. I believe the thermostat is out. It will run however. Price is negotiable, the car is in pretty good condition for its age a few dents on the body and a small spot of rust. Needs new tires and an oil change. Front seat back adjuster is broken
6-disc changer
Power windows
Sunroof
A/c
Heat works but is kind of weak
Power seats
New altnator
Changed tranny fluid at about 195,000
Battery is also new
That's just slush on the car paint is in good condition
Thanks.
Old 11-28-14, 11:47 PM
dicer
dicer's Avatar
Lots of stuff wrong with it. The over heating is likely from not much coolant flow or air lock, he says heat is weak. Only nice thing is the color, I don't like fabric seats though they wear better than leather, they just hold all the dirt and what ever else was spilled on them. Good parts car. For what you'd put into it a better bet is something 1200 or so more with no issues. Even a 93 up seen them around 2200 to 2500.
Old 11-29-14, 02:17 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
You should be able to get a much better example for not much more money. this one's been beat to hell and isn't worth that much more than what you'd get if you scrapped it out right now since the chassis' rusting according to seller.
Old 11-29-14, 08:10 AM
HotTubTony
HotTubTony's Avatar
Thanks guys.
Old 11-29-14, 12:29 PM
billydpowe
billydpowe's Avatar
Originally Posted by HotTubTony
Thanks guys.
give these guys a big pat on the back and do like PD says..
sayow
07-17-16 01:16 PM
LMoney4o8
19
02-28-14 04:59 PM
RandomHero
15
01-21-13 08:18 PM
turbo556
20
10-19-11 07:37 PM
Quick Reply: I need an armchair diag on this 90 LS
