anybody knows how to fix the following OBD1 codes????
Old 11-26-14, 10:53 PM
crazyg323
crazyg323's Avatar
Default anybody knows how to fix the following OBD1 codes????
Can someone help how to fix the following code check engine# 26, 71 transmission# 63, 67
Old 11-27-14, 07:26 AM
randal
randal's Avatar
The 26 is air-fuel rich mixture and 71 is EGR malfunction. So, I would do some searching into these two subjects.
What year, model and miles?
Here is a list of OBDI codes -> http://www.lexls.com/tutorials/intro/codereading.html
Old 11-27-14, 08:03 AM
billydpowe
billydpowe's Avatar
yes do some searching on the models like yours (what ever it is) there is plenty of help in the stickeys..
nobody can help you with a one sentence question...
check it out and tell us what you have done and what results you got and we can go from there..
good luck... and, welcome to the club
Old 11-27-14, 11:08 AM
dicer
dicer's Avatar
EGR could cause lean, ECU would compensate by making it fat, <--- old school term.
Was all this a sudden onset? If so could be the ECU caps issue.
Old 12-01-14, 12:46 AM
crazyg323
crazyg323's Avatar
Thanks for the advise guys... I just barely purchased a 1991 Lexus ls400 a lil over 300,000miles but it runs really strong all original nothing modified everything on the car works minus the obd1 code problems.... Next weekend replacing clutch speed sensor and solenoid#2 on the transmission.... What transmission oil are u guys using or what good aftermarket oil is good out there?
Old 12-01-14, 01:01 AM
dicer
dicer's Avatar
Amazon.com: Genuine Toyota Lexus ATF Type T-IV Automatic Transmission Fluid OEM 4 quart Type-4 ATF: Automotive Amazon.com: Genuine Toyota Lexus ATF Type T-IV Automatic Transmission Fluid OEM 4 quart Type-4 ATF: Automotive
This is for the photo. Price ? sometimes on sale at toyo dealer shop around.
Old 12-01-14, 01:06 PM
billydpowe
billydpowe's Avatar
WARNING: USE ONLY atf type IV AND use the same fluid in your power steering..
Old 12-01-14, 08:08 PM
Gene01
Gene01's Avatar
I thought the Power Steering specified Dexron.
Old 12-02-14, 02:37 AM
dicer
dicer's Avatar
It does, and that is what to use.
gr8wyt
10-16-16 02:23 AM
BigRon239
03-19-13 11:59 AM
tlex400
12-20-05 03:59 PM
moshlub
07-02-05 09:37 AM
Quick Reply: anybody knows how to fix the following OBD1 codes????
