RCA install question
How do you install front RCAs?
I have searched on the forum, i havent found an detail threads about how to instill them.
Is it just as simple as removing the two bolts on the bottom, then slap in the RCA then use the new hardware? If there is an threads out there but i didnt catch them, im sorry in advance.
Thank you,
-Matt.
Thank you,
-Matt.
BahHumBug
Thank you,
-Matt.
Thank you,
-Matt.
It is important that you torque the bolts down to the correct spec for your RCA, as usually this is considerably higher than the stock torque. Doubly important for Negative Camber RCAs.
There are several threads on this. Before we give you more information we need to know what kind of RCAs you have and what year your mitsubishi montero is.
Rymag
07-23-12 09:39 AM
melski415
03-25-12 12:25 AM
lexusscturbo
Suspension and Brakes
18
01-28-09 01:13 PM
