92 LS400 Tach Needle Fading/Flickers
hi all, just inherited a 92 LS400 and i have noticed that my tach needle flickers......sometimes its fully lit and other times the very tip of it is not lit. thought i would get some insight from you guys first before i do anything to it. just FYI everything else on dash works fine just the tach needle flickering at times thank you
I've added photos of it when its out but sometimes its lit ill try and get a photo when its fully lit
We can repair this. Call or email if interested. Otherwise DIY is somewhere on this forum. This is the most fragile cluster on the planet, very easy to break or throw the needles out of calibration.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
**UPDATED** 92 LS400 Tach Needle Fading/Flickering
I've found a solution that I'm going to do this weekend and will post results after but i have found a great tutorial that i wanted to post a link to the page i found so hopefully it will help others aswell
https://www.clublexus.com/forums/ls4...ml#post5072566
look @ post #289 by Amskeptic
Also if your clock/ Climate control lcd display is blacked out like mine is there is a tutorial i found for that too
http://www.lexls.com/tutorials/lighting/climateLCDscreen.html
SSAstro
11-08-12 06:39 AM
92ls400vip
07-30-07 04:40 PM
