This is an easy one...
Old 03-04-03, 05:05 PM
spxChrome
spxChrome's Avatar
Question This is an easy one...
Was fixing to start working on cleaning the throttle body when I noticed this piece is cracked (circled) and figured that is probally not a good thing since it is past the air filter. Anybody know what this tube is called so I can get a replacement? I am assuming that one end is the air filter and the other is the throttle body.
thanks
Old 03-04-03, 05:57 PM
Lextreme
Lextreme's Avatar
What is it called? I would say its a intake connector tube. This tube is after the MAF and it will affect your car Air/Fuel mixer. Your car will run better if you replace it. Best thing is get a new one from Lexus or get after market. The size is 3.25" ID and its about 3-4" long. If you want a used one www.car-parts.com will have it for cheap.
Old 03-04-03, 06:25 PM
spxChrome
spxChrome's Avatar
thanks, i will check with the dealership tommorow on a replacement. should cost to much?
was i right about that one end leads to the air filter and the other end connects to the opening of the throttle body?
Old 03-05-03, 08:13 AM
tenpointed
Banned
tenpointed's Avatar
I'm guessing that the "crack" is supposed to be there to allow the coupling to slide onto the throttle body easier. Notice that it is after the clamp, so no air or dirt should be able to get in there. I have a feeling that if you get a new one, the "crack" will come stock.
Old 03-05-03, 09:32 AM
ChrisK
ChrisK's Avatar
You can get it from the dealer, but the price could be about $80. You could order it from Parts Web Site for about $46. I just ordered by from the dealer and when I mentioned that I could get it for about $50 they told me that they will sell it to me at the wholesale price.
My also cracked at the same spot.
Old 03-05-03, 09:54 AM
spxChrome
spxChrome's Avatar
Well, I juste ordered it form the dealer. It was $48.33. But now you all have me interested in that crack. Can anyone else tell me if that is normal or not??
Old 03-05-03, 01:07 PM
TomWahjudi
TomWahjudi's Avatar
Default Cheap Fix
Well, if you want a cheap fix for that, go to Home Depot or any of your favorite hardware store. Go to plumbing department and ask for a 3" rubber hose connector. This shouldn't cost more than $6. And you even got the advantage of a smooth bore hose instead of an accordion-like bore that promotes turbulence. Bring your old hose and make sure that it matches very closely.
You can also go to NAPA and see if they have their straight radiator hose in 3 1/8". The exact hose size is actually 80mm, 3 1/8" is the closest but you can always use 3 1/4". If you decided to go to NAPA, they will only sell this thing in 3ft increment., so you will have extras. Let me know and I will buy a foot off of you
PS: that crack is probably caused by old age, the hose is 10+ years old and it has been exposed to pretty high underhood temperatures. C'mon, you cannot expect parts to last forever (especially filters ... hint, hint)
Old 03-05-03, 01:32 PM
BrianV
BrianV's Avatar
Whether it's supposed to be there or not I don't think it's harming anything due to the fact that the clamp is in place. Even enormous amounts of vacuum couldn't get air from that crack.
Old 03-05-03, 09:35 PM
meZoom!
Super Moderator
meZoom!'s Avatar
no, it's not supposed to have a crack there. Do yourself a favor and check your motor mounts too, if you haven't already. The way it happens is this:
motor mounts broken, engine moves around during driving. All flexible hoses/tubes get extra stretched and bent while engine moves around, eventually causing the tear.
glad you are getting it fixed. the longer you drive it like that, the worse it'll get: terrible acceleration, and an eventual "check engine" light.
Gs46046
01-20-24 12:16 PM
Brnlxndr
01-08-18 01:25 PM
matts6887
RX - 1st Gen (1999-2003)
03-08-15 02:39 PM
LsG86
02-27-15 04:20 AM
ShowGSLuVv
Performance
10-25-02 01:45 PM
Quick Reply: This is an easy one...
