dash light out on temp setting window 98 ls 400
Old 10-15-14, 08:14 PM
propman
propman's Avatar
Question dash light out on temp setting window 98 ls 400
dont know if anyone knows if there is a simple bulb to replace the light where you read and adjust the temp seating on the heat/ac. its a 1998 ls 400 with nav screen. just above nav screen the lights are out for the temp setting for the driver and passenger side. the center window has the time and outside temp........is it just bulbs? how to replace? thanks jimmy<")))))><
Old 10-15-14, 09:10 PM
Yamae
Yamae's Avatar
Those bulbs are not available. As far as I ask "Toyota Buhin Kyohan" which is a parts selling division of Toyota, those bulbs are not sold.
The link below shows how bulbs are mounted.
http://celsiorup.com/cgi/ita/file/1129453229.jpg
You need to remove the old bulbs using a soldering iron. I would simply use omni directional LEDs instead of old fashioned bulbs to fix.
jerryparks
10-12-12 12:41 PM
Oldeiron
02-20-10 08:47 PM
fongaroos
02-15-02 01:45 AM
Quick Reply: dash light out on temp setting window 98 ls 400
