95 Ls400 Knock Sensor Wire Location in ECU
Old 10-10-14, 04:50 PM
lightz
lightz's Avatar
Default 95 Ls400 Knock Sensor Wire Location in ECU
Hi Guys i have 1995 ls400 and trying to find the knock sensor wire located in the ECU and this pic show a Black and white wire next to each other so i don't know if these are the one's.
Old 10-10-14, 05:40 PM
Yamae
Yamae's Avatar
These are from a JDM manual but a USM should be the same as far as I know. Pin7 and Pin11 / connector B are them.
Attached Thumbnails 95 Ls400 Knock Sensor Wire Location in ECU-95-celsior-connector-a-d.png   95 Ls400 Knock Sensor Wire Location in ECU-95-celsior-ecu-connector-b.png
Old 10-14-14, 07:14 PM
lightz
lightz's Avatar
Hey thanks just has been hard to get this infor
Old 10-14-14, 07:15 PM
lightz
lightz's Avatar
Trying to bypass my knock sensor code p3025
Old 10-14-14, 07:16 PM
lightz
lightz's Avatar
Any one did this on ls400, i have seen it on other models
Old 10-14-14, 08:37 PM
Yamae
Yamae's Avatar
What do you mean by bypass?
Do you mean to disconnect the line or to connect the line to the ground aiming no signal from the sensor?
Old 10-16-14, 06:35 AM
lightz
lightz's Avatar
engine light on and p0325 show up just going to bypass it and used the other sensor just to pass emission. I seen see guys did it with rx300 models.
Old 10-17-14, 04:12 PM
lightz
lightz's Avatar
Yamae thanks for the infor about the ECU it pass the emssion and engine light is gone.
Old 10-17-14, 04:33 PM
Yamae
Yamae's Avatar
You are welcome.
Congratulations on your idea and the success.
Thanks for the report. Some people might be helped by your post in the future.
Old 10-17-14, 06:31 PM
timmy0tool
timmy0tool's Avatar
what exactly was done to 'bypass' the sensor?! i cannot imagine simply cutting the wires does the trick, or does it?!
Old 10-18-14, 01:09 PM
sha4000
sha4000's Avatar
I want to know also.
Old 10-19-14, 02:07 AM
Can
Can's Avatar
It does. What you need to do is expose the wires of Knock Sensor 2 ( I think P0330 ) , and splice the wires coming from Knock Sensor 1 to "fool" the engine into believing it's getting values from Knock Sensor 1 while it's actually just getting the same info as Knock Sensor 2.
I took the more expensive route and had the knock-sensor replaced, what a pain in the butt!!! 500+$ of parts and labor.
Old 10-20-14, 05:37 PM
lightz
lightz's Avatar
Can said it right, it was my knock sensor 1 p0325 cut and diconnect then used p0330 knock sensor.https://www.clublexus.com/forums/rx-...ck-repair.html
Old 10-20-14, 10:13 PM
cobalt91
cobalt91's Avatar
I understand needing to pass inspection, but aren't you risking more expensive damage by bypassing that sensor?
Old 10-20-14, 11:21 PM
Can
Can's Avatar
I haven't come across any people running into "more expensive" damage on their LS400's this way. If you wish to fix it, remove the throttle body and if you have the right tools, you can see both knock-sensors under the Intake Manifold. The process to reach them is the same as the Starter. Spare a day and 40$ from Junkyard if you're lucky.
Quick Reply: 95 Ls400 Knock Sensor Wire Location in ECU
