How do i take this off -fan bracket sub assembly
The fan broke and this is the fan bracket i believe i took out all the bolts i can see and it just won't move.. somewhere towards the driver side of the car is holding it in. Does anyone have advice or a step by step on how to get it out? PLEASE
There is a bolt just under the A/C compressor that you will need to remove. You may also need to bend a bracket back to get to it. Climb under the car and look closely for a bolt going thru the compressor. That is what is holding it. I do not think you will need to remove the compressor.
definitely there are 2 bolts that you need to remove, as well as a small electrical bracket.
one obvious one on bottom of the AC unit near the ground cable,
the second really long bolt goes through the ac unit and is in a bit of a tight spot although nothing is "tight" compared to the starter job.
the bracket you need to remove is on top of the AC compressor. regular screwdrivers dont quite fit so I used a couple extensions and a phillips bit socket point out towards the fuse box to remove the bracket screws
