1993 LS400 Electrical Problems
Old 09-22-14, 01:45 PM
txlex75154
txlex75154's Avatar
Default 1993 LS400 Electrical Problems
Ok, I have seen certain variations of electrical problems on the 1stGen LS400, but none that is exactly what I am experiencing. Hoping I can submit my problems to the gurus here and get a solution. Here goes:
At around the same time, the instrument display panel, telescoping steering wheel, and sunroof/windows all stopped working. The display panel will come on at random, but the windows/sunroof and steering wheel still don't function.
Has anyone else experienced all of these issues at once? I see a lot of info on the ECU capacitors needing to be replaced in order to solve the display panel issue, but would that solve the window issue also?
Old 09-27-14, 06:10 AM
hippystix
hippystix's Avatar
Default yes
I am also experiencing some what of the same problem. I am such an idiot, I hook up my battery backwards and now my windows and instrument panel doesn't work. I was able to get the windows working, with fuse #13. I have not been able to get the instrument panel working. I will need to run more test.
Old 09-27-14, 08:08 AM
RugbyDad
RugbyDad's Avatar
Check all fuses under the dash and under the hood.. Not just a visual inspection, sometimes there are really tiny breaks in the fuse and u can't see them with the naked eye..
If that's all good, check the trunk hinge wiring.. Sits on the drivers side near the tail lights if I'm not mistaken which I might b as I'm just relaying information I've read here on the forums..
The ecu caps should be replaced regardless of whether or not you think it's the culprit. I don't think they control the windows though.
GX470GT
05-25-11 03:05 PM
Exthultu
SC- 1st Gen (1992-2000)
09-27-10 01:32 AM
mmccutchin
17
03-11-06 11:46 AM
Quick Reply: 1993 LS400 Electrical Problems
