mk4 sc300/400 subframe in ucf10?
Old 10-01-14, 08:52 PM
004SLammed
004SLammed's Avatar
Default mk4 sc300/400 subframe in ucf10?
Hi I want to say ive spent a few days searching and have been able to see if anyone has swapped the rear subframe from a sc or supra into a early ls400... I have the diff with one dogear and I want to go to the 2 front mount style... the whole subframe isnt very much money and would allow different aftermarket options for suspension parts... any help on this would be appreciated. I will say I know the auto tt diff can be made to fit but I would really like to know about the subframe. Thanks.
Old 10-04-14, 10:07 AM
004SLammed
004SLammed's Avatar
Nobody knows?
Old 10-04-14, 12:49 PM
keeph8n
keeph8n's Avatar
No reason to when auto tt diff internals swap over
Old 10-04-14, 06:34 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the internals swap, the subframes will not just bolt in and require substantial fabrication and engineering to fit.
Old 10-06-14, 08:01 AM
004SLammed
004SLammed's Avatar
Thanks puredrifter. Keeph8n the diff is not a direct swap for the old ucf10. The later ls has the same center in it but from what I've read the older ones have a slightly larger differential in them which is not a direct swap. I have a sc300 pumpkin to swap just wanted to know about the subframe tho. I appreciate the responses anyways.
Old 10-07-14, 01:11 AM
PureDrifter
BahHumBug
AFAIK the early LS400s uses the same ring gear diameter as the later ones, everything should fit fine. Check part numbers for the pinion bearings between your LS and the SC you jacked the diff from.
Old 10-09-14, 01:25 AM
004SLammed
004SLammed's Avatar
Idk I read that the early years used a different diff size and it has only one front mount. Mine has one front mount and what im going to do with it I wanted the diff case that had two in front either way so its no big deal. Im going to be pretty hard on it and one mount seems like itll have quite a bit of movement...
Old 10-09-14, 03:52 PM
004SLammed
004SLammed's Avatar
looked into it further and it appears that I was reading bad information about the diff size. No matter tho I wanted the shorter gearing from the sc and the 2nd mount in the front of the diff case
lisc300
Performance & Maintenance
07-07-10 08:45 AM
simann
02-19-07 07:18 PM
757jetip
11-01-06 06:51 AM
Quick Reply: mk4 sc300/400 subframe in ucf10?
